Thread: Equally Spaced Lines of Text?
    100 Club dnilsson's Avatar
    2003-12
    Atlanta, Georgia
    109
    Default Equally Spaced Lines of Text?
    Is there any way to distribute individual text notes at an equal spacing? For example, on a wall section where the vertical space between notes is almost the same, but not quite.
    2002-02
    St. Louis, MO
    4,695
    Default Re: Equally Spaced Lines of Text?
    You could array one and then fill in the info. Not sure it is really worth it. As long as it is readable, who cares?
    2003-12
    Atlanta, Georgia
    109
    Well . . . I do. It's something that carried over from my lettering guide days I guess. It doesn't matter technically, the info is still there, but I like a detail that looks like it was composed and not just slapped together. Just something else that seems to be slipping away these days.
    The array would work if the notes were all one line or all two lines, but they rarely are so I guess I'll keep on with the eyeball method.
  1. Stretch box on both sides equally
    By vtmiii in forum Dynamic Blocks - Technical
    Last Post: 2016-08-05, 12:45 PM
  2. Stretch Equally 2 sides
    By Mac Demer in forum Dynamic Blocks - Technical
    Last Post: 2012-02-13, 01:04 PM
  3. All Families Are NOT Created Equally
    By seandburke in forum Revit Architecture - Families
    Last Post: 2009-12-15, 01:10 AM
  4. Elements Counted in Spaced Schedule
    By jason.combs in forum Revit MEP - General
    Last Post: 2008-08-25, 06:52 PM
  5. EQUALLY SPACED SYMMETRICAL GRIDS
    By captainbunsaver in forum Revit Architecture - General
    Last Post: 2006-12-20, 03:01 AM
