By default AutoCAD will start-up with the Imperial template, how to change it to metric, so every time I start-up AutoCAD, it give me metric, so I don't need to change it.
thxs for anyone can help
Jack Cheong
Jack Cheong
You can set the template for startup / qnew in the options\files\template settings\default template file name for qnew.
Or you could simply change the MEASUREINIT to 1, this will automatically use the ACADISO.DWT for QNew.
But I'd also advise using steve's method. You can setup your own custom DWT file with all Layers, Dimstyles, etc. already done and then set QNew to use this instead.
I have my standard template set up the as the qnew template and it starts a new drawing1 using my template when I open autocad. I get no popup box.
I have a PC setting:
C:\Documents and Settings\user\Local Settings\Application Data\Autodesk\AutoCAD 2009\R17.2\enu\Template
It open up a metric template, and the other had the same setting for Drawing Template File Location open a imperial template
Anything else I need to set?
rgds
Jack Cheong
In the default template, highlight the current selection, select the browse button, and select the *.dwt template file that you want to use as the default.
The template file location setting should be the directory as you have it.
I always have my templates in a directory that I easily use if I upgrade/rebuild etc, C:\cad\template\. When I worked for a larger company this was a network drive to share. The default autodesk location is to hard to find.
To get rid of the dialogue set STARTUP to 0 (zero).
