Thread: Creating beams as vertical members
    2009-07
    38
    Default Creating beams as vertical members
    I am trying to create a roof frame that has sloped W12 rafters with W8 "legs" that are about 4' tall. I can put the rafters in as beams and create a work plane to slope them and they will miter nicely at the ridge. But I only know how to put the W8 legs in as columns and then Revit will not miter the W12's and W8's. Is there a way to put in a vertical element as a beam?
    Thank you.
    2002-09
    Madison, WI
    5,443
    Default Re: Creating beams as vertical members
    I would place the W8 vertical using a brace, and use the beam tool to place the W12. Adjust the end to get the slope height you want. Create a temp elevation view of the objects. At a ref plane where the miter line would be. Use the cut geometry tool, select the ref plane as the cutting line. You'll need to do that to both the W8 & the W12. Then you can create a model group. When you create the group be sure that you select the ref plane as well. Then you can copy the group and all should be fine.
    Make sense?
    Dave Peterson
    BIM Coordinator
    Acad - 2016 - Revit 2018 w/ A360 - Navisworks - 3ds 2018 - Ensacpe - Lumion - Win 7 64 - i7-6700K 4.0GHz 32GB DDR4 Ram - Nvidia Quadro K2200
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
    2009-07
    38
    Most of it made sense, but how do I actually draw the brace as a vertical member? Thanks.
    2002-09
    Madison, WI
    5,443
    1 members found this post helpful.
    Create a framing view on the grid line of choice. Go to that view and draw it vertical. You may want to draw a vert ref plane to make it vertical or pick a grid line. Once you have the vertical element, just move it to the correct location in plan.
    Dave Peterson
    BIM Coordinator
  1. 2014: Creating Vertical Steel Members that Aren't Columns
    By chrisd385116 in forum Revit Structure - General
    Last Post: 2015-02-20, 12:27 AM
  2. 2013: Problem creating a vertical array
    By ccenergy in forum Revit MEP - Families
    Last Post: 2012-08-10, 08:26 PM
  3. Replies: 13
    Last Post: 2010-11-02, 03:04 PM
  4. CW Mullion Join Leaves Gaps in Vertical Members
    By c.senior in forum Revit Architecture - General
    Last Post: 2009-07-16, 08:01 PM
  5. curved beams in vertical plane
    By tripon.ciprian in forum Revit Structure - General
    Last Post: 2007-11-19, 12:21 AM
