Thread: realtime takeoffs?
    2004-06
    58
    Default realtime takeoffs?
    Does anyone have input on how to update an existing takeoff with new Revit-based DWF data? I have learned that for manual on-screen takeoff data one can copy/paste takeoff items to new DWF sheets BUT for 3D dwfs with model takeoffs it's not so obvious what the workflow would be.
    I see that the object handles are the same so it would seem it might be possible to re-map the takeoff items to a new DWF. I have exported the QTO catalog and reimported into a new project with the updated 3D DWFs but I could not get the new takeoff objects to map to the previous takeoff items as I'd hope I'd be able to do. Perhaps I'm missing some important step?
    To re-state, for those using Revit-based data what ability would you have to update your QTO project as the Revit data progresses? Is this practical right now in QTO? Any input is appreciated.
    Regards,
    Glynnis Patterson, Architect
    www.ideatebimlink.com | www.ideateexplorer.com
    I could stop if I wanted to David Haynes's Avatar
    2003-05
    Seattle, WA
    222
    Default Re: realtime takeoffs?
    From what I have heard the following:
    1. Save catalog from previous QTO file (using previous saved dwf.
    2. Create new Revit DWF - based on new information.
    3. Start new QTO file and import new DWF and import saved catalogs.
    David Haynes, AIA, LEED AP
    Director of Consulting
    Ideate, Inc.
    www.ideateinc.com
    2006-05
    835
    If you want all the information from a Revit file on top of the 2D sheets. Create a wireframe 3D view in Revit and place the view on a sheet. This will include all information and will connect into the dwf.
    AJS
    BIMM Consultant
    www.GHD.com
  1. Help with Pan Realtime
    By cgruen in forum AutoCAD LT - General
    Last Post: 2010-08-23, 04:46 AM
  2. Duct Takeoffs
    By finney13 in forum AMEP General
    Last Post: 2008-08-25, 03:26 PM
  3. Steel Takeoffs
    By lmnewkirk in forum Revit Structure - General
    Last Post: 2007-12-18, 11:17 PM
  4. Wheel Mouse button not Pan Realtime
    By charles_paquette in forum AutoCAD CUI Menus
    Last Post: 2005-05-23, 08:43 PM
