Thread: adding plate to underside of beam
    2015-09
    146
    Default adding plate to underside of beam
    i was just wondering if there is a way where you can add a flat plate to the underside of a beam to show steel picking up brick work ?
    is it a way of editing the family or can you just draw it in on plan ?
    cheers for your help
    2008-11
    Australia
    754
    Default Re: adding plate to underside of beam
    Quote Originally Posted by K.ATHERTON View Post
    I hope Im understanding what you need properly, however, if it was me I would use a face based plate (Place this under modelling>component) in your 3d view you just select the component under the modelling tab and hover over the underside face of the beam and this plate should attach onto that.
    You will need to alter the dimensions on it once you've placed it to suit your plate size...
  1. 2013: RHS/SHS beam with edge plate
    By lomo2002 in forum Revit Structure - General
    Last Post: 2013-05-06, 03:46 PM
  2. 2013: How to cut out the top of a Grade Beam for 2x6 plate!
    By Cosmic Traveller in forum Revit Structure - General
    Last Post: 2013-04-11, 06:53 PM
  3. Attach wall to underside of beam and constrain
    By d_lee.162829 in forum Revit Architecture - General
    Last Post: 2008-07-02, 05:34 AM
  4. Attaching Wall to Underside of Beam
    By nsinha73 in forum Revit Architecture - General
    Last Post: 2008-02-25, 07:30 PM
  5. Beam with Hung plate
    By Galadriel in forum Revit Structure - General
    Last Post: 2008-02-11, 05:56 PM
