Results 1 to 10 of 16
Thread: Change Text to Bold
    2007-09
    10
    Unhappy Change Text to Bold
    I have many, many independent text items that I want to change from regular to bold (not all the text in the drawing but most of it). I tried making one group bold then matching properties...that does not work for "bold". I tired many things that did not work. I don't want to go through and hi-lite each line and select bold...would take all day. That is the only way I know how to do it. Does anyone know a easier way?
    2005-06
    in the upper right corner
    3,019
    Default Re: Change Text to Bold
    Quote Originally Posted by dhf000 View Post
    You must be talking about a True Type Font (TTF)?
    I'm not sure how (and if) you can do what your asking, but if it were an SHX font, you could put the text you want bold on a layer that plots darker (wider lineweight), not sure if it would work for TTF.
    Just a thought
    Ted
    ____________________________________________________________________ ________________
    Windows 7 Professional
    AutoCAD 2017 - REVIT 2017 - Inventor Professional 2015 (when I can)
    Houston
    9,184
    Like Ted wonders... Is the text SHX or TTF?
    You could always create a new textstyle and then move the desired text to the new "bold" style too...
    R.K. McSwain | CAD Panacea |
    2007-09
    10
    It is TTF. Not that proficent with AutoCAD...doing this layout as public service for local cementery. It is all the plot numbers. I did it...had to convert to pdf for kinkos. With normal text it was alittle fuzzy in pdf so thought I would try making bold...thought it woulb be easy until I discovered I could only do it by opening each text string, hi-lite and then making it bold...one at a time. I tried to create style but not too sure how to implement. Got any simple instruction?
    0,0,0 The Origin
    8,569
    Create a new textstyle (Style command) using a suitable font. You can set Bold, change the height, whatever. Then select all the text items that you want to change and use the Properties Manager to set them to use the new style.
    John B
    Active Member dsthilare's Avatar
    2008-02
    Vancouver, BC
    57
    As it seems its not for a standardized drawing, I would use a new layer thats has a thicker lineweight.
    CADApe - no monkey here
    Houston
    9,184
    Arrow Re: Change Text to Bold
    Quote Originally Posted by dsthilare View Post
    IIRC -- Lineweights and/or plotstyles with thicker lineweights have no effect on text created with TTF.
    2007-09
    10
    Quote Originally Posted by jaberwok View Post
    I tried and have set up a style for the text I want...it will not change the text to bold on my drawing. I select many text items, go to the properties and select the new style..it does not change the text to bold. I appreciate all the suggestions but I am not getting anything that is working.
    I have attached a portion of the drawing for example. Again my goal is to change the text to bold without having to go to each one, hi-lite and then make bold...too time consuming for the many I have to do.
    Houston
    9,184
    1 members found this post helpful.
    Something we all overlooked, although we were missing a critial peice of information...
    This is MTEXT, not TEXT, and the MTEXT contains embedded formatting, which overrides the properties of the applied textstyle.
    You need to get rid of the embedded formatting if you want this MTEXT to take on the properties of the textstyle assigned to it.
    Edit an MTEXT item, and when you are in edit mode, press Ctrl+A to select all the text, then right-click and select Remove Formatting > Remove All Formatting.
    There is also a lisp routine available here to globally remove embedded formatting from a selection set of MTEXT entities.
    http://cadabyss.wordpress.com/
    2005-06
    3,019
    Yea, I tend to agree ...that what I was thinking when I wrote:
    ....but if it were an SHX font, you could put the text you want bold on a layer that plots darker (wider lineweight), not sure if it would work for TTF.
    Ted
  1. 2013: Text showing different heights on BOLD
    By tace86152814 in forum Revit Architecture - General
    Last Post: 2012-11-14, 01:49 AM
  2. 2013: How to Remove BOLD from within Text notes?
    By ddraynor in forum Revit Architecture - General
    Last Post: 2012-09-24, 01:42 PM
  3. Italic / Bold Text
    By jonathanm in forum Revit MEP - General
    Last Post: 2009-05-08, 02:46 PM
  4. Dimension text with Arial Bold
    By Henry D in forum Revit Architecture - General
    Last Post: 2006-12-17, 08:27 PM
  5. AutoCAD 2007 - DWG to PDF causes my Text to look bold
    By pangell in forum AutoCAD Plotting
    Last Post: 2006-06-12, 09:05 PM
