Thread: Duct Riser Clearance & Beveled Tap
    2009-07
    3
    Default Duct Riser Clearance & Beveled Tap
    I have two questions,
    1. How can you add or show clearance space around a duct riser in a shaft. I can draw lines, but this does not work well. I need to show a dashed lines 6" around all my risers.
    2. I have a duct riser, and I have a duct takeoff on a floor, when I connect the duct to the riser, the beveled tap is either going to the left , or to the right, how can you get the beveled tap to go vertically upwards.
    2005-08
    11,000 feet atop a chute
    1,001
    Default Re: Duct Riser Clearance & Beveled Tap
    Quote Originally Posted by Gindelicato View Post
    1. If the lines are just for graphic purpose and not being used for conflict, I would just use detail lines. You can offset 6" and trace your risers.
    2. You have to rotate the segment of duct connected to the HET fitting in section.
  1. Add Riser diagram for pipes and duct
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2014-04-19, 03:40 PM
  2. 2014: Duct riser/drop symbol
    By madeel495827 in forum Revit - Platform
    Last Post: 2014-02-20, 08:35 PM
  3. Add Duct Riser Symbols - Wye Filled & Reverse Wye Filled
    Last Post: 2012-11-14, 04:32 PM
  4. Beveled Tap
    By tys90 in forum Revit MEP - General
    Last Post: 2011-07-18, 09:30 PM
  5. Beveled take-off
    By mcasella in forum Revit MEP - General
    Last Post: 2010-10-18, 01:51 PM
