Results 1 to 9 of 9
Thread: Weights and center of gravity (Am I Pushing the Revit Limits)
    All AUGI, all the time DoTheBIM's Avatar
    2005-02
    Central PA, USA
    753
    Default Weights and center of gravity (Am I Pushing the Revit Limits)
    So the boss has this idea that he wants to implement. Assemble trusses, sheathing, felt paper, bracing, etc on the ground. crane it up 5 storys and set in place. I've created a model in Revit and views to represent what we want to do. So I was thinking a bit beyond like normal and was wondering if I could calculate the center of gravity of this assembly and the assembled weight. Anyone have any ideas? Eye candy attached.
    I already tried exporting to AutoCAD and using mass properties but I can't change denisities. Revit has a place in materials to enter material weights but, where can I see this data output to?
    Certifiable AUGI Addict cliff collins's Avatar
    2004-05
    St. Louis, Missouri
    3,135
    Cool Re: Weights and center of gravity (Am I Pushing the Revit Limits)
    Interesting question.
    Sounds like a job for Revit Structure, Tekla, or some other 3rd party app that will
    calculate those variables from the model.
    Catia can probably do this--and there is an "architectural workbench" version
    of Catia that Ghery Partners has developed--very pricy, though.
    See if your Structural engineer can shed any light? Do they use Revit Structure
    or Navisworks, Tekla, RAM, etc?
    Let us know your findings........
    cheers.
    Cliff B. Collins, Registered Architect / BIM Specialist
    St. Louis, MO
    2005-02
    Central PA, USA
    753
    Default Re: Weights and center of gravity (Am I Pushing the Revit Limits)
    Hahaha. Our structural engineer...if only. Anyway... I figured there were other programs that could accomplish this (thanks for the list), but was wondering what the purpose of the weights in the materials are if one cannot do any totals calculations for them. IOW... what was the intention of having that kind of data exposed in Revit? Are they exposed in Revit Structure for calculations like this? I could download the trial version and give it a go if so.
    2002-09
    Madison, WI
    5,474
    Ahh, but you can.
    You just need to schedule it. However, it won't give you the desired result, just the total weight.
    You can get the total steel weight of a structure either by member type or total.
    Take a look on the RS side of things, I know that question has been solved before. But I don't think you can get the centroid of the panel. But that's not really what you want anyway. You want the center of the mass at the top, not the center of the panel since you'll be picking it from the top. Now you've got a little bit of an issue.
    Dave Peterson
    BIM Coordinator
    Acad - 2016 - Revit 2018 w/ A360 - Navisworks - 3ds 2018 - Ensacpe - Lumion - Win 7 64 - i7-6700K 4.0GHz 32GB DDR4 Ram - Nvidia Quadro K2200
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
    2005-02
    Central PA, USA
    753
    I'm not seeing where I can add the Material weight to the schedule. Volume is the closest I can seem to get it in RAC2009
    2002-09
    Madison, WI
    5,474
    Try this or This
    Dave Peterson
    BIM Coordinator
    2005-02
    Central PA, USA
    753
    ahh i see... thanks for that. Those threads applied to mostly component families and my assembly is mostly system families. so I applied the shared parameter via project parameter and it works. All accept for my masses... Why did I make an in place mass... <sigh> Anyway at least there's a semi automatic way to calculate total weight.
    2004-05
    St. Louis, Missouri
    3,135
    Red face Re: Weights and center of gravity (Am I Pushing the Revit Limits)
    Good tips, all.
    So--a "mass" has no "mass"? Irony at its finest...............
    cheers.
    St. Louis, MO
    2005-02
    Central PA, USA
    753
    oh it has a mass but it appears that masses aren't material schedulable (<- Is that a word? ;D)
  1. SE322-1: Pushing Autodesk Revit to Its Limits: Creating Non-Building Revit Families
    By Autodesk University in forum Structural Design and Engineering
    Last Post: 2014-12-01, 03:38 AM
  2. CP12-2: Pushing AutoLISP® to the Limits
    Last Post: 2013-04-17, 04:44 AM
  3. Center of Gravity (COG)
    By Darkskys in forum Inventor - General
    Last Post: 2008-04-23, 01:59 AM
  4. center of gravity
    By shawnk in forum MDT - General
    Last Post: 2004-11-13, 03:18 PM
