Firstly, I am new to Robot. So the following may be a rookie error...
The issue I have is the following:
The structure being analyzed is a rectangular building - steel roof trusses pinned to concrete columns on RC foundations supported by an elastic soil (uplift is permitted, i.e. no soil tension)
The following load cases are applied:
DL1 - Permanent Dead Load (incl self weight)
DL2 - Non-Permanent Dead Load (not to be taken into account under wind loading)
LL1 - Live Loading
EP1 - External wind pressure 1 - push-over wind force
Suction on roof
Pressure on LHS column
Suction on RHS column
EP2 - External wind pressure 2 - suction
Suction on roof
Suction on LHS column
IP1 - Internal wind pressure - positive pressure
IP2 - Internal wind pressure - suction
Analysis Type:
Non-linear P-delta
Combinations (factors not shown)
DL1 + DL2 + LL1
DL1 + EP1 + IP1
DL1 + EP1 + IP2
DL1 + EP2 + IP1
DL1 + EP2 + IP2
Robot analyzes the cases indivudually, however, the uplift wind forces are incompatible with the supports and causes non-convergence.
It is not possible for the wind forces to exist without the structural dead load.
What is the correct way of dealing with this?
