Below is part of a lisp I have for inserting a titleblock. I will attach this file as well, so it is available for testing. I have this lisp working perfectly w/ another titleblock and this is a direct Save As of the previous lisp and titleblock. Now I am getting an error. The best I can tell, when the (If (= el (entlast)) line runs, it is coming up as =, and it shouldn't be at that point. Can someone check this thing out and help me? Any other info you need, etc. just let me know and I will get it for you ASAP.
I have 8 different titleblocks I need to modify this Lisp for, so I want to get it RIGHT this time instead of having to mess w/ it 8 different times.
Thanks in advance!
Steven
Code:; ProESubm_FabB.lsp ;;;-------------------------------------------------------------------- ;;; M A I N F U N C T I O N ;;;-------------------------------------------------------------------- (princ "\nProESubm_FabB Insert") (Defun C:ProESubm_FabB (/ OSN LA n0 n1 n2 thei tlen A0 A1 A2 A3 A00 ws xscl yscl dwgscl rtio scls R0 R1 P0 P1 P2 P3 shtscl tx txlist pmt1 edf u uprec ) (Command "Undo" "Mark") (Setvar "Cmdecho" 1) (Setvar "Limcheck" 0) (Setvar "Blipmode" 1) (Setq OSN (Getvar "Osmode") u (Getvar "Lunits") ;Save Unit type uprec (Getvar "Luprec") ;Save Unit precision LA (Getvar "CLAYER") ;Save current layer ) (Setvar "Osmode" 0) (Setvar "Lunits" 2) (Setvar "Luprec" 8) (Setvar "Plinewid" 0) ;;;-------------------------------------------------------- ;;; Set Coordinates for Working on Title Block ;;;-------------------------------------------------------- (Setq n0 (list 0.0 0.0) ;Lower Left Node n1 (list 0.07000000 0.90000000) ;Lower Left Bdr Pt n2 (list 16.25000000 10.20000000) ;Upper Right Bdr Pt A0 (/ (- (Car n2) (Car n1)) 2) ;Half of drawing width A1 (/ (- (Cadr n2) (Cadr n1)) 2) ;Half of drawing height A00 (list (+ (Car n1) A0) (+ (Cadr n1) A1)) ;Center of Dwg Space ) ;;; ----------------------------------------------------- ;;; Fill in title block info ;;; ----------------------------------------------------- (Setq Proc (getstring T "\nEnter Process: ") Desc1 (getstring T "\nEnter Description Line 1: ") Desc2 (getstring T "\nEnter Description Line 2: ") DrwBy (getstring T "\nEnter Drawn By: ") ChkBy (getstring T "\nEnter Checked By: ") DwgNo (getstring T "\nEnter Drawing Number: ") ShtNo (getstring T "\nEnter Sheet Number: ") TotSht (getstring T "\nEnter Total Number of Sheets: ") Rev (getstring T "\nEnter Revision: ") RevDesc (getstring T "\nEnter Revision Description: ") Date (getstring T "\nEnter Date: ") ) ;;;-------------------------------------------------------- ;;; Window Extents, Calculate Scale, ;;; and Move to Center of Dwg Space ;;;-------------------------------------------------------- (Command "Zoom" "Extents") (Setq P2 (Getvar "EXTMAX") P1 (Getvar "EXTMIN") thei (- (Cadr P2) (Cadr P1)) tlen (- (Car P2) (Car P1)) A2 (/ thei 2) A3 (/ tlen 2) P0 (List (+ (Car P1) A3) (+ (Cadr P1) A2) ) ) ;;;--------------------------------------------------------------------- ;;; Calculate "xscl" - Drawing Scale Required Horizontally ;;;--------------------------------------------------------------------- (Setq xscl (/ tlen (* A0 2))) ;used A0 to control width instead of constant ;;;--------------------------------------------------------------------- ;;; Calculate "yscl" - Drawing Scale Required Vertically ;;;--------------------------------------------------------------------- (Setq yscl (/ thei (* A1 2))) ;used A1 to control width instead of constant ;;;--------------------------------------------------------------------- ;;; Set "dwgscl" - Overall Drawing Scale ;;;--------------------------------------------------------------------- (If (>= xscl yscl) (Setq dwgscl xscl) (Setq dwgscl yscl) ) (Setq scls (List 0.25 0.5 1 2 3 4 5 5.3333 6 8 10 12 16 20 24 30 32 40 48 50 56 60 64 72 96 100 120 128 144 160 200 240 296 320 360 400 480 560 600 640 720 960 1200 1280 1400 1920 2400 3840 ) R0 0 R1 (length scls) ) (While (< R0 R1) (If (And (< (nth R0 scls) dwgscl) (>= (nth (1+ R0) scls) dwgscl) ) (progn (Setq dwgscl (nth (1+ R0) scls) R0 R1 ) ) (progn (Setq R0 (1+ R0)) (If (= R0 R1) (Setq dwgscl (nth R0 scls)) ) ) ) ) ;;;--------------------------------------------------------------------- ;;; Calculate the Center of New Dwg Space ;;; and Move Contents to that Center ;;;--------------------------------------------------------------------- (Setq edf (rtos dwgscl 2 4)) ;set edf = dwgscl to 4 decimal places (While (/= edf nil) (Setq A4 (* (- (Car n1) (Car n0)) dwgscl) A5 (* (- (Cadr n1) (Cadr n0)) dwgscl) n1 (List (+ (Car n0) A4) (+ (Cadr n0) A5)) A6 (* (- (Car A00) (Car n0)) dwgscl) A7 (* (- (Cadr A00) (Cadr n0)) dwgscl) P3 (List (+ (Car n0) A6) (+ (Cadr n0) A7)) ws (* dwgscl 5) ;Window Size for Editing Title Block ) (Command "Move" "all" "" P0 P3) ;;;------------------------------------------------------- ;;; Place Border ;;;------------------------------------------------------- (Setvar "ATTDIA" 0) (Setvar "ATTREQ" 0) (Setvar "CLAYER" "0") (Setq el (entlast)) (Command "Insert" (findfile "N:/Engineering Data/Software/AutoCAD/AutoCAD Common/Templates/Fab-B-new.dwg" ) n0 dwgscl "" 0 ) (If (= el (entlast)) (progn (Print "No Border Placed") (EXIT) ) ;end progn (Setq el (entlast)) ) ;end (If (= el (entlast) (If (Or (/= (cdr (assoc 0 (entget (entlast)))) "INSERT") (/= (cdr (assoc 2 (entget (entlast)))) "Fab-B-new.dwg") ) (progn (Print "No Border Placed") (EXIT) ) ) (Command "'Zoom" "Extents") ) )
