I have installed sharenow setup2010 and nothing shows up in Revit. It does however show up in AutoCAD. Anyone else had this?
i have the same issue.
it shows up on acad 2009, but not revit 2009.
running Revit 09 64 bit
Steve, Sharenow is an addin that publishs your model to freewheel where people can view the file via a hyperlink using their browser. The advantage is that they don't need to download additional software like design review. Sound great huh... well if you can get it to work, it is!
Cool, hadn't heard of that, I'll have to check it out, thanks!
just downloaded and installed the extension. The attached warning came up when I first started Revit, aparently I've gotten ahold of some very advanced software from the future, good to know that Revit will still be around in 30 years though!
I fixed the path in the Revit.ini file and all seems to be working now for me...
Ah yes, the Revit 2040 release.... those were the good ole days. I miss the holographic interface with the telepathic add-on.
sure:
EAName4=ShareNow
EAClassName4=Autodesk.Freewheel.RevitAddin.ShareNowApp
EAAssembly4=C:\Program Files\Autodesk\Freewheel Client for Autodesk 2010 Products\RevitShareNow.dll
of course you'll have to change the 4 to whatever it is in your sequence...
