I originally placed this under a similar thread and reposted this to keep the focus on bounded volumes.
I am trying to figure out the Bounded volumes calculation for C3D and I am getting ridculous volumes, maybed I am just going about this in the wrong manner, but even the C3D help says:
Use the Bounded Volume utility to calculate the volume of an area as defined by a polyline,or polygon, or parcel.
You can quickly calculate and display the net volume, cut, and fill for a bounded area on a volume surface.
NoteFor volume surfaces, the volume of the bounded area is based on the difference elevations that were originally used to calculate the volume surface. For terrain surfaces, the volume is calculated from the 0 elevation to the elevations in the bounded area.
If this is calculated from the 0 elevation how is this going to help me, the volume seems to be calculating from 0 to my 4938 elevation instead of 4935 to 4938. Do I have to move my polyline/polygon to the bottom elevation of my ditch and then calculate?
