Thread: Why won't some triangles quadify
    AUGI Addict Andre Baros's Avatar
    2003-12
    Point of no return
    1,604
    Angry Why won't some triangles quadify
    I have geometry imported from Revit which I would like to refine before rendering. I have a bunch of flat planes which I need to bevel and I need to quadify them first to get rid of a bunch of really narrow triangles. There is no reason for these faces to have triangles, they are simple rectangles... I tried optimize, quadify, a few other things, is there some magic to imported geometry which would keep this from working?
    Thanks
    Design Visualization Moderator stusic's Avatar
    2004-10
    N32° 32' 19.08", W-84° 52' 59.03"
    1,305
    Default Re: Why won't some triangles quadify
    There may very well be other, easier ways, but from the Max Help file (under "Quad Meshing"):
    You can apply quadrilateral tessellation to a mesh object without necessarily performing an actual Boolean operation on it. First create an additional object that's not touching the object you want to tessellate. Select the object to tessellate, apply ProBoolean, turn on Make Quadrilaterals, and then subtract the other object. You can then collapse the tessellated object to Editable Mesh/Poly if you like.
    Phillip Bradshaw
    Lead Pixel Pusher, Lucid Design Studio
    CAD Administrator, Heatcraft RPD
    A doctor can bury his mistakes but an architect can only advise his clients to plant vines. - Frank Lloyd Wright
    I could stop if I wanted to loydg's Avatar
    2007-08
    Denver, CO
    325
    If you are using 2010, there is a new modifier called "Quadify MEsh." You can always remove it if it doesn't work the way you want it to!
    Glen Loyd
    Parsons Brinckerhoff
    Lead Design Visualization Specialist
    3ds Max Design 2010 Certified Associate/Professional
    www.pbprojectviz.com
    www.pbviz.com/forum
    2003-12
    Point of no return
    1,604
    The new modifier is precisely where I started, it works on some faces and not others. I thought that the problem was with the new tool, but any way I tried, the triangles didn't go away. I finally remodeled it but I'm still currious why it isn't always possible to clean up some (many) meshes from Revit).
  1. Those DAMN triangles!!
    By pauljordan in forum NavisWorks - General
    Last Post: 2013-03-28, 03:04 PM
  2. HELP WITH ANNOYING TRIANGLES
    By RollTide72 in forum AutoCAD General
    Last Post: 2011-07-27, 05:15 PM
  3. Geodesic Dome with equilateral triangles
    By hugotavares6 in forum Revit - Conceptual Design Tools
    Last Post: 2010-10-17, 07:24 PM
  4. can not use crossing window to edit triangles in tin files
    By rjairath in forum AutoCAD Civil 3D - General
    Last Post: 2007-12-18, 02:23 PM
