Results 1 to 7 of 7
Thread: Door with 'Healing' Sidelights Mystery
    100 Club jpolding's Avatar
    Southwestern Ontario
    198
    Default Door with 'Healing' Sidelights Mystery
    Please find attached a door and window combination that I made as a test a year ago or so. There are nested windows on each side of the door which have Visibility Parameters for right and left. When this is inserted into a project and the Visibility Parameters are switched, the wall hole 'heals'. I can't remember how I did this. I think that I have narrowed it down to a setting in the window template but I can't duplicate it with another window/door combo. AND IT"S DRIVING ME CRAZY. Anyone know what I'm forgetting?
    Jay Polding
    Toronto Blue Jay
    Ontario Users Group Blog: http://orug.ca
    My Revit Blog: http://revit.blogspot.com/
    AUGI Addict jsteinhauer's Avatar
    2015-11
    Madison, WI
    1,317
    Lightbulb Re: Door with 'Healing' Sidelights Mystery
    Quote Originally Posted by jpolding View Post
    My guess is that since the nested window family already has a wall void in it. When you turn it off, it turns off the wall void too.
    Jeff S.
    198
    Default Re: Door with 'Healing' Sidelights Mystery
    Thanks for the guess Jeff but that's not it. When I try this with another window type it leaves a gaping hole!
    Jay Polding
    Toronto Blue Jay
    2015-11
    Madison, WI
    1,317
    I was half right. You created the void with an opening. The opening apparently act very differently then a void. More important things have been discovered by accident then on purpose. This may want to go into the tips section.
    Jeff S.
    2015-11
    Madison, WI
    1,317
    Unhappy Re: Door with 'Healing' Sidelights Mystery
    Quote Originally Posted by jsteinhauer View Post
    Jeff S.
    After doing some more testing, I've found I am wrong. I don't know what is happening in this family. Seriously what & how did you do that?
    Sorry,
    Jeff S.
    2015-11
    Madison, WI
    1,317
    Sorry,
    Jeff S.
    I'm a stubborn one. But, I got an answer that truly works. I promise!!! You're nested window family is setup as shared. The visibility control then allows the cut openings to be removed for whatever reason. I need to research shared families more. They're really beginning to peek my interest.
    Cheers,
    Jeff S.
    198
    Cheers,
    Jeff S.
    Thanks Jeff! That is indeed it. Thought I checked that but I guess not. Thanks again.
    Jay Polding
    Toronto Blue Jay
  1. 2012: Ceilings are not Healing. Apparently component holes are permanent?
    By essochay in forum Revit Architecture - General
    Last Post: 2011-07-22, 04:52 PM
  2. Door Schedule MYSTERY!!!!
    By Baldwin_4-6-0 in forum Revit Architecture - General
    Last Post: 2007-06-01, 04:00 PM
  3. Sidelights don't load
    By abink in forum Revit Architecture - General
    Last Post: 2006-09-01, 12:41 AM
  4. Mystery door arrow
    By jaroguy in forum ACA General
    Last Post: 2006-07-18, 04:16 PM
