Thread: 3D blocks-command line vs dialogue box?
    2009-08
    3
    Default 3D blocks-command line vs dialogue box?
    I need to enter thousands of attributed blocks into a drawing. The attributes need to be viewable in both plan and section views so I created a block with 2 attributes, one in plan UCS, one in section UCS. This worked great in demo when I entered the insertion coordinates in the insert dialogue box. But if I enter the coordinates on the command line, as I have to do if running a script file, both attributes are displayed in plan view.
    Can anyone suggest a way around this problem?
    many thanks
    Alistair
    Certifiable AUGI Addict
    2015-11
    Jo'burg SA
    4,512
    Default Re: 3D blocks-command line vs dialogue box?
    Welcome to AUGI congrats on your 1st post.
    Even if I use DDINSERT on your block, both ATTRIB's are placed on the current UCS. However, my tip is to run ATTSYNC just after inserting all the blocks.
  1. 2016: Command Dialogue Box Flashes On Then Disappears
    By Lucius in forum AutoCAD General
    Last Post: 2015-11-04, 03:30 PM
  2. Replies: 6
    Last Post: 2010-04-29, 06:16 PM
  3. AutoCAD opening files in command line, not dialogue box
    By emlyn_altman in forum AutoCAD General
    Last Post: 2009-12-17, 02:08 PM
  4. Command Line instead of Dialogue Box
    By archdraught in forum CAD Management - General
    Last Post: 2008-09-26, 07:09 AM
  5. Property Line Dialogue: Redesigned
    By Chad Smith in forum Revit Architecture - Wish List
    Last Post: 2003-09-03, 08:54 PM
