Thread: Offset Objects are sent to origen point
    2004-08
    4
    Red face Offset Objects are sent to origen point
    For not known reasons when I use offset command onto lines or shapes smaller than 1000mmx1000mm with closed angles lines like square, the offset lines do not appear next to the original line, instaead they appear gathered over the origin point. Does some one knows on any setting that may be cauysing this strange behaveour?
    I o appreciate someone help
    2001-10
    Arizona
    2,337
    Default Re: Offset Objects are sent to origen point
    You can see that this goes back a ways Problems using the offset command
    And this may not be anymore help: Offsetting complex polylines other
    to show that it is a problem that you may need to
    find a way around.
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
  1. Need program to create simple AutoCAD point objects from point file
    By Bob T in forum AutoCAD Civil 3D - General
    Last Post: 2009-09-08, 10:51 PM
  2. Point vertical offset list
    By wayneb in forum AutoCAD Civil 3D - Land Desktop Companion - General
    Last Post: 2009-04-22, 08:55 PM
  3. Moving Text Objects relative to base point as other Objects are moved / scaled
    By William Troeak in forum Dynamic Blocks - Technical
    Last Post: 2007-02-06, 01:35 PM
  4. offset civil point object
    By chrisw.94380 in forum AutoLISP
    Last Post: 2006-03-10, 04:34 AM
  5. point blocks/civil point objects
    By 348PATTERSON in forum Land Desktop - General
    Last Post: 2005-01-07, 09:34 PM
