Thread: xref fading
    2006-02
    Edmonton Alberta
    30
    Question xref fading
    Hello All,
    My question is as follows.
    Situation:
    In my general arrangement drawing, that consists of several xrefs, made up of solid models, I have been trying to find out if there is a way to fade an individual xref, so that it becomes semi-transparent while maintaining the solidness of the other xrefs.
    I am trying to make it so that I can see through a building to see the contents of the building, in this case the piping and vessels contained within.
    Is there an easy way to do this or is this to be a wish list item.
    Currently using Autocad 2010.
    I hope this makes sense. Any help is greatly appreciated
    0,0,0 The Origin
    8,570
    Default Re: xref fading
    Simple answer = no (unless someone knows otherwise).
    You could assign a "glass" type material to the enclosing object and/or create a translucent Visual Style.
    2006-02
    Edmonton Alberta
    30
    Thanks for the response.
    I didn't think there was a way but one just never knows.
    I will try the glass material idea and see if that works.
  1. 2014: fading raster fdo connection
    By cadtag in forum AutoCAD Map 3D - Data Connect (FDO)
    Last Post: 2015-03-12, 05:46 PM
  2. 2014: Fading Linked CAD
    By Kevin Gatzke in forum Revit - Platform
    Last Post: 2013-04-29, 06:02 PM
  3. Fading levels below!
    By craighowie in forum Revit Architecture - General
    Last Post: 2011-01-19, 04:39 PM
  4. Image Fading?
    By g_wong in forum AutoCAD General
    Last Post: 2009-06-17, 05:15 AM
  5. Fading Locked Layers
    By Firmso in forum AutoCAD General
    Last Post: 2008-07-07, 11:27 PM
