Thread: Elevation Surface Property Data Entry
    2008-05
    7
    Default Elevation Surface Property Data Entry
    I am struggling to find the settings for controlling the precision within the data entry dialog box. I have set the precision to two decimal places and it shows up correctly in the chart as shown in the attached image (Elev_Table.jpg), but entering the data in the dialog box I have to mentally keep track of what I had entered because it seems to be rounding the number as shown in the attached image (Elev_Table_Dialog.jpg).
    I would like to set the precision so that I can see exactly what I have entered into the dialog box, but I have yet to find the settings that controls this.
    Any thoughts?
    Thanks
    Jesse
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Default Re: Elevation Surface Property Data Entry
    It looks like that display is controlled by Drawing Settings -> Ambient Settings -> Elevation.
    2008-05
    7
    Thanks
    That was it. I had it set for an override precision of (2) or 0.00, but evidently the override does not work and seems meaningless. Setting the precision in the ambient settings does work.
  1. Data Entry in Room Schedules
    By MikeJarosz in forum Revit Architecture - General
    Last Post: 2012-04-11, 09:47 PM
  2. Rebaring by data entry in member's property
    By ljupadhyay in forum Revit Structure - Tips & Tricks
    Last Post: 2011-07-12, 06:08 PM
  3. Schedule Data Entry
    By wadeshuey in forum Revit Architecture - General
    Last Post: 2010-02-12, 08:33 AM
  4. Create Property Line By Table - Revise Arc Entry
    By kspear in forum Revit Architecture - Wish List
    Last Post: 2007-09-06, 06:01 PM
  5. Automation - 2 data entry problems
    By avinash00002002 in forum VBA/COM Interop
    Last Post: 2006-05-18, 07:54 AM
