Results 1 to 10 of 10
Thread: Phasing - Wrongly rendering window as demolished
    2008-10
    279
    Default Phasing - Wrongly rendering window as demolished
    Hi all,
    Having lots of fun breaking Revits phasing system at the moment!
    I am rendering a demolished view, and it looks great (origional building in 'clay' demolished parts in bright red) - but Revit is for some reason rendering a window in the demolished style, when the window is an existing component that isn't demolished at all...
    Why?! What's it done now?! Any ideas how to fix it?!
    Any help appreciated! : )
    2008-10
    279
    Default Re: Phasing - Wrongly rendering window as demolished
    I also have a window on the other side of the building which IS demolished, but renders as existing!
    AUGI Addict jsteinhauer's Avatar
    2007-09
    Madison, WI
    1,029
    Quote Originally Posted by jayc View Post
    I don't have an answer for you, besides maybe delete the window and re-insert it. But, I would triple check the settings of that instance. I know this may be counter productive, but have you also tried to slide the window down the wall? For some reason, it may think it is being demolished, because it is in the vicinity of something else that is being demolished (I don't think this is true though).
    I hope this helps,
    Jeff S.
    2008-10
    279
    Hi Jeff,
    Thanks for the input - I'll give re inserting and nudging things about a go!
    Fingers crossed...
    2008-10
    279
    Okie dokie...
    Managed to fix one!
    I changed the window type first - the new type rendered fine. When I changed back to the original type - It was still broken.
    I moved it around the wall a bit - Still broken.
    Deleted it, and re-inserted it - Still broken...
    So, I made a duplicate of the window type that was rendering as demolished (when it was totally UN demolished), and changed only this problem window to the new type.
    The original type remained on other windows which were to be demolished, but the new type on this problem window seems to have sorted it out (for some reason).
    Why is always WORKAROUNDS with Revit?!
    2008-10
    279
    This technique worked with the other problem window also (which was being shown as UN demolished when it should have been demolished)
    It seems to be something to do with the view being rendered having multiples of the same type of window, and then some of these being demolished and others not.
    Any ideas why?
    All AUGI, all the time Elmo's Avatar
    2005-04
    South Africa
    959
    are you sure it isn't just a phase filter selection that could be doing this to you? Have you tried setting the phase filter to complete, to show the completed building instead of filtering new or existing?
    2008-10
    279
    No other filters show the previous (existing building) with the demolished elements.
    The elements show fine in any normal view - only when rendered does the problem arise.
    The work around has worked - it'd be good to know why it was happening though...
    2005-04
    South Africa
    959
    Interesting. Possible bug perhaps?
    2008-10
    279
    Maybe... I tend to find at least 3 "bugs" a day though
  1. Wall replaces demolished window
    By cees.vanancum in forum Revit Architecture - General
    Last Post: 2010-04-01, 02:50 PM
  2. Rendering Phasing Problem
    By silas.seger in forum Revit Architecture - General
    Last Post: 2009-12-09, 07:08 PM
  3. Window / Door phasing problems
    By jyoungner in forum Revit Architecture - General
    Last Post: 2008-06-04, 11:12 AM
  4. Phasing and Rendering
    By pwmsmith in forum Revit Architecture - General
    Last Post: 2005-08-09, 02:41 AM
