Results 1 to 10 of 13
Thread: running 32 bit autocad on 64bit XP...
    2015-09
    Toronto, ON
    93
    Question running 32 bit autocad on 64bit XP...
    We are getting some new PC's and our IT guy has a good price on some 64-bit XP systems.
    we are concerned about running a 32 bit autocad 2009 on a 64 bit XP system. Are there any known problems with this combination?
    thanks in advance!
    0,0,0 The Origin
    8,569
    Default Re: running 32 bit autocad on 64bit XP...
    I thought A2009 came with both versions on one disc?
    If that's right, the 64-bit version will be installed.
    John B
    2015-09
    Toronto, ON
    93
    hm. interesting idea.
    unfortunately i don't have the discs any more. they walked away one day and haven't been seen since. i DO have one of the discs on our network for easy installation. so if its all on one disc i may be in luck... i'll have to check that out.
    0,0,0 The Origin
    8,569
    Well, it should work anyway but acad will be installed into the "Program Files (x86)" folder.
    Edit -
    Probably WRONG. 32-bit version will not install on 64-bit Win 7 so probably not on 64-bit XP either but both versions ARE on the disc so it doesn't really matter.
    John B
    2001-11
    200
    Sorry to butt in on this conversation, but I have AutoCAD 2006 and was wondering if I was to buy a new laptop which has Windows Vista and had 4Gb Ram which I am then assuming would run vista 64 bit, will 2006 still run on this laptop if not would AutoCAD 2007 be any better.
    (Cannot afford to upgrade at the moment)
    Any advice appreciated.
    Regards
    Neil Cheshire
    0,0,0 The Origin
    8,569
    Quote Originally Posted by neilcheshire View Post
    Regards
    Neil Cheshire
    Hang on for a couple of months and get Windows 7 instead of Vista - it's FAR superior. It runs applications better, faster, smoother.
    But it won't run A2006. so Vista might not either (can't actually check Vista).
    Edit - Win 7 won't run A2007 either.
    Edit 2 - this is 64-bit Win 7.
    John B
    2001-11
    200
    I believe that Windows 7 will be supplied with an emulator of some sort that will run XP programs whether this will allow us to run AutoCAD 2006/2007 will be interesting to see.
    0,0,0 The Origin
    8,569
    As I understand it, only the higher levels of Win7 (Professional, Ultimate) will have the emulator and the processor, motherboard and BIOS all need to be suitable.
    John B
    2001-11
    200
    Thanks I believe you are right. Will 2007 definitely not be able to run on Windows 7? Are there any 3rd parties who could provide some sort of emulator.
    2001-05
    Austin, TX USA
    2,201
    Quote Originally Posted by emodderman View Post
    If your on subscription you should be able to download either version from the subscription center if need be. Also I believe your reseller could find a disk to give you as well.
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
  1. Windows 8 - Has anybody run AutoCAD on Windows 8 64bit?
    By Curt340924 in forum Operating Systems
    Last Post: 2014-04-11, 03:59 PM
  2. Autocad 2012 and Windows 7 64bit
    By tcrain1981 in forum Hardware
    Last Post: 2012-07-30, 04:52 PM
  3. AutoCAD 2010 on 64bit Machine
    By Spenner in forum AutoCAD General
    Last Post: 2011-07-02, 11:53 PM
  4. Revit AutoCAD Suite 64bit?
    By ftonelli in forum Revit MEP - General
    Last Post: 2009-02-13, 02:01 PM
  5. Trying to load Autocad Map 3D on Vista 64bit?
    By jthornton.45133 in forum AutoCAD Map 3D - General
    Last Post: 2008-12-12, 04:04 PM
