Thread: Beam cutback in plan for wood beams
    2007-10
    61
    Default Beam cutback in plan for wood beams
    I am setting up a framing plan in a project that has all wood construction. The second floor framing is 2x8's bearing on 5 1/4" x 16" parallam beams. These beams are setting on wood parallam columns. The only way I can get the "stick" beam framing in plan to cut back the correct way is to raise the top of the columns to the top of the beam (like the beams are framing into the sides of them). If I model it correctly (with the beams on top of the columns) the beam in plan does not cut back. Am I missing something here? Thanks.
    Steve Blackburn
    Frost Engineering and Consulting Co.
    2006-05
    836
    Default Re: Beam cutback in plan for wood beams
    If you setup in the families an additional instance parameter to control the analytical model you may find this easier.
  1. 2013: Specific instances of beam symbolic cutback not working as desired
    By BrendanOG in forum Revit Structure - Families
    Last Post: 2014-02-28, 06:20 PM
  2. 2013: Joist Cutback Distance in Plan View
    By dbumgarner in forum Revit Structure - General
    Last Post: 2013-04-09, 01:30 PM
  3. Beams in Residential Wood Frame
    By 3dway in forum Revit Architecture - General
    Last Post: 2011-05-24, 09:33 PM
  4. Beam cutback distance.
    By jmctamney in forum Revit Structure - General
    Last Post: 2008-05-15, 09:39 PM
  5. Custom beam stick symbol cutback
    By ck.107547 in forum Revit Structure - General
    Last Post: 2007-12-13, 11:33 PM
