Thread: Gap Between Grid Head and Grid Line
    2007-01
    29
    Default Gap Between Grid Head and Grid Line
    I am using the hexagon grid head, which I have made smaller per our office standard. Doing this creates a small gap between the head and the line. How do I extend the line to touch the head?
    2007-03
    Melbourne, Australia
    278
    Default Re: Gap Between Grid Head and Grid Line
    Just check the grid head family and possibly turn on the reference planes you need to make sure it is in the correct positon in the family and ref planes are often turned off on annotation familes
    2007-01
    29
    I checked the position relative to the reference planes, and it is exactly centered over the intersection of the two planes. Any other thoughts?
    2007-01
    29
    I found it! There are two lines of invisible line type that I reduced in length, which fixed the problem.
  1. 2014: Section Head - Stagger Offsset Callout like Grid Head
    By Limbatus in forum Revit Architecture - General
    Last Post: 2014-11-27, 01:08 AM
  2. 2013: Another grid head question..
    By AndreasK in forum Revit Architecture - General
    Last Post: 2013-02-05, 02:19 PM
  3. Grid Head Position
    By jboone_lri in forum Revit Structure - General
    Last Post: 2011-05-19, 02:02 AM
  4. grid head family
    By drakir in forum Revit Architecture - Families
    Last Post: 2008-06-17, 12:27 PM
  5. Grid Head / Grid lines on separate export layer
    By Griff in forum Revit Architecture - General
    Last Post: 2004-02-10, 10:02 PM
