Thread: Fascia Joins
    I could stop if I wanted to Batman's Avatar
    2004-12
    332
    Default Fascia Joins
    Why is that Revit can handle fascia joins on the downward slope end of a roof to horizontal connection properly but the upper slope end doesn't join??
    Anyone have a solution AKA "work-around"??
    Thanks in advance.
    2006-03
    Japan
    47
    Default Re: Fascia Joins
    Hello BAtman. I work in AUtoCAD. About the second attachment,I use the line which I made with a 3dpoly command for a pass. The section becomes a solid with a sweep command. I think that there is a similar function in Revit Architecture.
    I could stop if I wanted to nole's Avatar
    2004-10
    Moscow, Russia
    401
    Hi there.
    It seams that there are two facias in that corner. It won't work, it should be one facia for proper joining.
    Оr You picked wrong line during facia making.
    2015-10
    Wellington , NZ
    565
    Hi,
    see attached example.
    revit can handle the seamless joining OK (although this tool does have very limited functionality unforunately).
    Several things need to be true.
    The roof plane or planes need to be co-planar in the sense of one geometry, for the automatic joining of fascia and/or gutter runs.
    You can get 2 separate roofs that need to meet at some point - (see 2nd image where a small new gable end had to be joined into extg truss roof and the eave / soffit had to be aligned (in reality, the existing trusses to this area remained in place and the new ones bear upon them).
    Here The new work is a separate piece of roof geometry positioned to suit the soffit and the fascia runs were stopped in the internal corner, and returned as were the gutter sections and these aligned and joined correctly even though, they are not part of the same roof geometry.
    All the alignments need to be the same and the selection edge of course must be the same however, this will work.
    regards
    trombe
    2004-12
    332
    The fascia I have created is a "single" element.
    I have tested several different scenarios and there are no real problems with the fascia tool, except for the situation where an upward pointing fascia ends at the top of a slope and then any horizontally abutting fascia needs to meet it. As I have shown in my pictures above the join does not occur.
    This is peculiar because it works in the reverse, which is essentially a similar situation. That is where the downward pointing end of the fascia at the bottom end of a slope meets and joins any horizontally abutting fascia.
    This problem can be replicated in any Revit version.
  1. Roof fascia - "Can't create Fascia"
    By tomm in forum Revit Architecture - General
    Last Post: 2014-05-14, 04:05 PM
  2. Dormer and Fascia
    By ddelaney.wit750576 in forum Revit Architecture - General
    Last Post: 2011-06-17, 06:42 PM
  3. Fascia not mitering
    By dzatto in forum Revit Architecture - General
    Last Post: 2010-05-04, 02:21 PM
  4. fascia
    By ntnik in forum Revit Architecture - General
    Last Post: 2008-07-17, 03:48 PM
  5. Fascia
    Last Post: 2006-06-08, 05:19 PM
