Is it possible to path my custom tool pallete to my USB drive? Id like my home and work environments to be identical without having to update both when I make a change.
Thanks
Thanks
Yes. Add the flash drive as a Tool Palette location in the Options dialog, Files tab. It would help if your flash drive has the same drive letter associated with it each time you use it on a given computer.
Thank You David. It took me a few days to get back to this question. My drive always comes up as E:\ Now I should be able to get things the same at home and at the office.
