Thread: Trouble creating surface from DEM
    2009-04
    12
    Default Trouble creating surface from DEM
    I have downloaded some dem files from the USGS site and I am trying to create a surface from that data. I can create a surface based on the dem, but it is extremely small. I don't think that it is using the correct coordinates for some reason. The dem is a rather large area, but in c3d it less than .1" across. Can anyone give some help as to how to get the surface to be the correct size? Thanks, RJ.
    2006-12
    Loveland, CO
    734
    Default Re: Trouble creating surface from DEM
    Make sure you you assign the appropriate coordinate systems when you add the DEM.
    2009-04
    12
    I assigned the coordinate system for the dem in that window but it does not change anything. When I reopen that window, without doing any other operation, it looses the coordinate system that I put in there and is blank again.
    2006-12
    Loveland, CO
    734
    Do you have a coordinate system assigned to the drawing under the drawing settings?
    2008-06
    The Yay! (Bay Area, CA)
    131
    You have to use Lat/Long 83. It will set the correct sub set for your local coordinate system but use the 83 lat/long code and it will work perfect.
  1. 2014: Trouble with Creating Cross Sections
    By bmac2012 in forum AutoCAD Civil 3D - Sections
    Last Post: 2014-11-14, 05:52 PM
  2. 2012: Trouble creating form
    By damon.sidel in forum Revit - Conceptual Design Tools
    Last Post: 2013-12-02, 09:30 PM
  3. 2013: trouble creating dormer openings.
    By Bluefairy in forum Revit Architecture - General
    Last Post: 2013-03-26, 02:31 PM
  4. Trouble Adding Surface Line
    By jacunningham428299 in forum AutoCAD Civil 3D - General
    Last Post: 2012-10-09, 09:24 PM
  5. I am having trouble creating a Doric column
    By bcreehan in forum Revit Architecture - General
    Last Post: 2010-03-17, 09:14 PM
