Thread: Changing font size in within MTEXT edit mode.
    I could stop if I wanted to Merlin's Avatar
    2004-05
    Brisbane, Australia
    405
    Question Changing font size in within MTEXT edit mode.
    Greetings!
    An interesting hurdle. In the recent past few releases, when I've opened a piece of Mtext, I've been able to select a portion of the text and change the text size of that text selected. This size could be something I could type in at that point.
    With the new format, this doesn't seem to be supported. I select the text, and , yes, it can be changed to a size that has been used previously (in the pull-down list) BUT not a new size.
    Is this something to do with the "Annotative" abilities? Is there a system variable / default that can be changed?
    John Mc
    0,0,0 The Origin
    8,570
    Default Re: Changing font size in within MTEXT edit mode.
    I can highlight the height value in the combo box and replace it so your problem is probably connected with annotative features (which I don't use).
    HTH
  1. Display size of Mtext in Mtext editor
    Last Post: 2006-07-12, 03:11 PM
  2. Set up font size in AutoCAD to mimic Word text size
    By panchalashi in forum AutoCAD General
    Last Post: 2006-05-29, 12:22 PM
  3. Changing font without changing Text Style.
    By zoomharis in forum AutoCAD General
    Last Post: 2006-03-22, 05:51 PM
  4. how to edit/change text size in mtext
    By sbradford in forum AutoCAD General
    Last Post: 2005-11-20, 08:05 PM
  5. Edit mtext size (mtextfixed)
    By mlepelletier in forum AutoCAD General
    Last Post: 2005-10-21, 06:20 PM
