Results 1 to 9 of 9
Thread: Get rid of exclamation sound
    2007-10
    7
    Default Get rid of exclamation sound
    Every time I put an object on a layer that is off or frozen Acad throws up a warning window and plays the windows default exclamation sound. Is there a way to make Acad stop playing the sound?
    0,0,0 The Origin
    8,570
    Default Re: Get rid of exclamation sound
    Go to Options\System tab, uncheck "beep on error in user input".
    2007-10
    7
    Still there. Maybe a system variable that can be turned off?
    2004-08
    Iron Station, NC
    3,198
    change the EXPERT system variable and the alert will go away. I believe it is windows causing the sound, not AutoCAD
    2007-10
    7
    Thumbs up Re: Get rid of exclamation sound
    Perfect! Thank you!
    2017-09
    Quote Originally Posted by ccowgill View Post
    How would you go about changing that?
    Earth
    9,804
    Quote Originally Posted by colincooper24755722 View Post
    At the AutoCAD command line, type in the sysvar EXPERT, and change the value.
    R.K. McSwain | CAD Panacea |
    2005-06
    Atlanta
    118
    3
    You can also make sure your Windows sound for "Exclamation" is set to none. Right click sound in system tray and choose Sounds, or go to Control Panel/Settings and find Sounds. Click on the list of Program Events, scroll or type "E", and then change whatever sound file is shown to None.
    You can also turn off all sounds there, in the menu above called Sound Scheme, but some prefer to still get alerts for email, etc. Your preference.
    2015-10
    Indiana
    2
    Thanks so much, this was very useful!
  1. 2013: material exclamation mark
    By jledgewood in forum Revit Architecture - General
    Last Post: 2014-05-01, 05:04 PM
  2. Dialog Box with Exclamation point
    By lnewcombe in forum AutoCAD General
    Last Post: 2012-08-28, 01:06 PM
  3. Annoying exclamation point
    By mwalker.87963 in forum AMEP General
    Last Post: 2009-07-27, 07:37 PM
  4. Exclamation icon missing
    By ron.moss in forum Dynamic Blocks - Technical
    Last Post: 2008-01-19, 03:42 PM
