Thread: Duplicate parameters in different Shared Parameter logs
    2006-01
    306
    Default Duplicate parameters in different Shared Parameter logs
    Our company has some older families that were created using a Shared Parameter log file: SP1.txt
    We've learned a lot since then and have re-tooled how we do families and parameters. So, we created a new Shared Parameter log file: SP2.txt
    Some of the parameters contained in SP1 and SP2 are the same name. For example, we have a light fixture with Shared Parameter "Switching" from SP1. We also, have a fixture tag using the same parameter from SP1. We created a new light fixture with a Shared Parameter "Switching" from SP2. If we tag the new fixture in a project, the Label for Switching displays a "?" even though the fixture Switching value is "A3".
    This tells me that "Switching" from SP1 does not equal "Switching" from SP2.
    So, I need to fix the old tag to point to the new Shared Parameter log file: SP2. However, when I try to edit the Label that is pointing to "Switching", I can't remove the parameter. There is an icon to do so, but it is inactive (grayed out). I can add the new "Switching" parameter from SP2, but then I have two parameters with the same name and can't tell which is old and which is new.
    How can I remove the old parameter from the family, so I can add the new one without redundant names?
    P.S. don't tell me I need to create all new families using the new Shared Parameter log.
    2015-12
    Los Angeles, CA
    211
    Default Re: Duplicate parameters in different Shared Parameter logs
    You can use the purge command to remove it.
    2006-01
    306
    Quote Originally Posted by ededios View Post
    OK, I found if you delete the Label within the tag, the parameter disappears automatically from the parameter listing. Creating a new Label allows me to place the new parameter from the other Shared Parameter log. That delete parameter icon was confusing me.
    2015-12
    Los Angeles, CA
    211
    Sorry for the confusion. . . Yes, I had the same thing, I didn't understand what the delete and edit parameter options are there for, they're not active.
    I didn't delete the label I edited, switched it to another, and like it did for you it was automatically not listed once I exited the dialog.
    2006-01
    306
    The other really cool thing is when the "Edit Parameter" icon is enabled, and you click on it, everything on edit window is inactive. Thanks for trying.
  1. TOTAL COMPLETE, Revit Master Parameter List & Shared Parameters
    Last Post: 2017-05-16, 04:19 PM
  2. The order of parameters in a shared Parameter
    By lmjwrb in forum Revit Architecture - Families
    Last Post: 2010-10-01, 08:32 PM
  3. duplicate shared parameters
    By jpcowan in forum Revit Architecture - General
    Last Post: 2010-04-29, 06:12 PM
  4. how to remove duplicate shared parameter name
    By Ning Zhou in forum Revit Architecture - General
    Last Post: 2010-01-18, 05:21 PM
  5. Replies: 1
    Last Post: 2008-05-02, 10:50 PM
