Thread: AMEP 2010 XREF Problem
    2009-09
    68
    Default AMEP 2010 XREF Problem
    Hi Guys,
    New to the forum, wondered if anyone could help out with an MEP issue we are currently experiencing.
    We had a similar problem with ACAD 2010 but it was resolved by installing the latest 'Service Pack 1' update on the Autodesk Site.
    When we try and insert Xrefs into MEP it flags up an error message
    IMAGEATTACH - Invalid File
    The Problem can be caused by several things:-
    -The data in the file is corrupt
    -The file is an earlier format and no longer supported
    -The file format is not supported
    Our other offices that use the same software and systems that we use have not experienced the same problems which is strange. I have tried a repair and a complete uninstall to see if this rectifies the problem. Unfortunately this has not resolved the issue.
    Additionally I wondered if anyone knew how to get MEP to return to the 'classic look workspace'
    Administrator RobertB's Avatar
    2001-08
    Dallas TX USA
    5,829
    Default Re: AMEP 2010 XREF Problem
    You are probably going to need to wait for the update for AutoCAD MEP 2010 to resolve the image attach issue.
    It is strange that your other offices are not seeing the issue. I guess they dodged the bullet.
    On the other issue, since MEP's CUI file does not have menus or toolbars defined, you are going to have some serious reinventing of the wheel to do to try to get a classic look.
    R. Robert Bell
    Design Technology Manager
    S P A R L I N G
    Opinions expressed are mine alone and do not reflect the views of Sparling.
  1. Autocad LT 2010 xref problem
    By dangolboom in forum AutoCAD LT - General
    Last Post: 2010-07-13, 07:45 PM
  2. Amep Architecture 2010 and Aca 2010
    By fathibaali in forum ACA General
    Last Post: 2010-01-28, 12:43 PM
  3. AMEP 2010 to Navisworks
    By dhagenbuch in forum AMEP General
    Last Post: 2009-12-03, 04:47 AM
  4. AMEP 2010 XREF printing
    By robertfran in forum AMEP General
    Last Post: 2009-11-12, 06:03 PM
  5. Amep 2010 installation
    By fathibaali in forum AMEP General
    Last Post: 2009-04-15, 09:13 AM
