Thread: Transferring Site Data Between Revit Architecture and AutoCAD Civil 3D
    AUGI Addict jeffh's Avatar
    2002-09
    Manchester, NH
    1,087
    Default Transferring Site Data Between Revit Architecture and AutoCAD Civil 3D
    This skill builder is a series of videos that show how to share and manipulate site data (Survey Points and Project points) in Revit Architecture and AutoCAD Civil 3D. The use of the Globe Link extension is also shown allowing you to publish your Revit designs to Google Earth.
    http://usa.autodesk.com/adsk/servlet...linkID=9243097
    Certifiable AUGI Addict
    2004-05
    St. Louis, Missouri
    3,135
    Cool Re: Transferring Site Data Between Revit Architecture and AutoCAD Civil 3D
    Jeff,
    We have had an issue with Globe Link for Google Earth, when the Revit model is imported
    and "attached to the ground plane", the roofs of the buildings take on the slope of the
    topography--ie they do not stay horizontal. Have you seen this, or is it a known issue?
    cheers......
    2002-09
    Manchester, NH
    1,087
    Default Re: Transferring Site Data Between Revit Architecture and AutoCAD Civil 3D
    It is not an issue that I have heard before, but to be honest I have not really used Globe link a whole lot. On this tutorial I picked a site in flat Minnesota so I would not have run into the problem you are describing. I will see if I can find anythign related to that problem and ask product support if they have heard of something like it.and let you know.
  1. Replies: 0
    Last Post: 2014-12-01, 04:36 AM
  2. Replies: 0
    Last Post: 2013-05-05, 03:25 AM
  3. New Robot models inheriting old data when transferring from Revit
    By leon.sullivan181291 in forum Robot Structural Analysis
    Last Post: 2011-09-08, 01:25 PM
  4. Transferring ownership of architecture model
    By grudy in forum Revit Architecture - General
    Last Post: 2010-08-18, 12:42 PM
  5. Transferring Pipe Data?
    By RevitNinja in forum Revit MEP - General
    Last Post: 2009-07-06, 10:12 PM
