Results 1 to 7 of 7
Thread: HVAC Zone Color Legend
    2007-04
    61
    Default HVAC Zone Color Legend
    I am preparing a schematic report for a new job, and we typically show color block diagrams of AHU zoning. I have grouped my spaces into zones that represent AHUs (for now). I have assigned a color fill scheme to the Zones, and the floor plans look the way I want them to. However, I would also like a legend to show up keying the colors to the AHU numbers. It seems like when you apply a color scheme like I did, that a legend automatically pops up, and you have the option to hide it. But the legend doesn't show up, and I can't figure out how to get it to show up. I have checked the V/G settings, and "Color Fill Legends" is checked. I searched the help file and this forum, and have only found ways to rename the legend or hide the legend. How do you get the legend to show up? Has anyone tried this in 2010 yet?
    2003-04
    Irvine, CA
    6,773
    Default Re: HVAC Zone Color Legend
    The Legend tool is found on the Architect ribbon tab...as shown in the attached image. Obvious location Is this what you are having an issue with?
    2003-06
    Manchester, NH
    222
    The "legend" is an annotation element that needs to be added to the view.
    It appears that the only place to access this legend in Revit MEP is on the Architect Ribbon, on the Room & Area pane (middle right button).
    Pipe and Duct legends (which are different than the zone / space / room legend) can be accessed on the analyze tab.
    jason
    2007-04
    61
    that's what I was looking for! Thanks!
    As a suggestion, this should be placed elsewhere OR the button should be renamed "color fill legend". I had assumed that this button made a new symbol legend. I see that when I click on Legend, it goes to a contextual ribbon that is labeled "place color scheme legend" but it's still a rather obscure location. I assume from the responses that I'm not the only one with this opinion.
    AUGI Mom CADMama's Avatar
    2000-06
    Where reference planes have Defines Origin checked
    985
    Can you get the legend to be a halftone?
    I can get the area plan colors halftone but I cannot find where to get the legend halftone.
    Donnia Tabor-Hanson
    AUGI Mom
    AUGI Membership Coordinator
    GO Vols!
    Nana is the best job I have ever had - pays well too!
    A woman is like a tea bag - you can't tell how strong she is until you put her in hot water. - Eleanor Roosevelt
    2007-06
    Des Moines, IA
    222
    Quote Originally Posted by CADMama View Post
    I don't believe you can, the Annotation Category "Color Fill Legends" has the Halftone box grayed out, there is no check box to make it halftone. There may be a workaround but the initial answer is no.
    2000-06
    985
    That is what I thought.
    I told them just to change their colors all the way around. If they want them halftone then just make them halftone and the legend would be the same.
    Donnia Tabor-Hanson
    AUGI Mom
    GO Vols!
  1. HVAC Zone Legend for multiple views
    By adonkle in forum Revit MEP - General
    Last Post: 2011-10-18, 09:52 PM
  2. HVAC Zone Trouble
    By fduraes in forum Revit MEP - General
    Last Post: 2009-09-29, 03:47 PM
  3. Mechanical(HVAC) Zone is not exported to IFC 2X3
    By bingcat2007 in forum Revit MEP - General
    Last Post: 2008-10-25, 01:25 PM
  4. Filtered color legend
    By mtogni in forum Revit Architecture - General
    Last Post: 2006-12-06, 02:01 AM
