Results 1 to 9 of 9
Thread: rendering elevation views
    2008-05
    Honolulu
    334
    Talking rendering elevation views
    how do you set up a view so that it is an orthographic elevation
    so that you can render it...
    rendered elevations views look really great on a set of plans.
    r
    2003-10
    Santa Barbara
    397
    Default Re: rendering elevation views
    View, Orient, North south etc
    only problem is that skys dont render in ortho views
    but you can drop in a sky in a photoshop background layer
    2008-05
    Honolulu
    334
    ok, that worked
    I think you could huge wall behind the building and assign a sky image to it if needed
    haven't tried tho....
    personally, want to really want to do the renderings in 3dsmax...
    r
    2005-12
    566
    Yeah, Max is better.
    "Rock-n-Roll Architect" SCShell's Avatar
    2004-01
    Tucson, AZ
    1,272
    Hey there,
    Even easier.....save your rendered elevation as a PNG file. Then open a drafting view in Revit, import you favorite sky or background photo, then import your rendered PNG file. Play with them a bit to adjust and Voila! Just export it out as a JPG or PNG using Masking Regions to get rid of overhanging sky backgrounds etc.
    Good Luck
    Steve
    Photoshop not required.
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Heres and example we did in revit. The - revit is without any background work, the -reduced is with the background work.
    Scott D. Brown, AIA
    BECK
    2003-10
    Santa Barbara
    397
    One advantage to photoshop is you can apply filters
    this one has a watercolor filter to soften it up a bit
    2008-05
    Honolulu
    334
    Talking Re: rendering elevation views
    wow nice renderings
    just curious how did you do the spanish tile
    it looks like it is modeled not just an image
    r
    2003-10
    Santa Barbara
    397
    yes they are modelled w/ line line based tile family, its the only way to get a decent look, slows the model down like crazy but you can always turn them off
  1. Rendering Internal Views
    By Anfield in forum Revit - Tutorials
    Last Post: 2007-03-01, 05:11 PM
  2. Elevation Views - Is rendering possible?
    By sfraney in forum Revit Architecture - General
    Last Post: 2006-06-29, 09:12 PM
  3. Rendering an Elevation...
    By twiceroadsfool in forum Revit Architecture - General
    Last Post: 2006-01-27, 12:30 PM
  4. Replies: 4
    Last Post: 2005-10-18, 12:58 PM
  5. Elevation Rendering
    By cphubb in forum Revit - Rendering
    Last Post: 2004-06-04, 08:43 PM
