Thread: system specs
    All AUGI, all the time Bryan Thatcher's Avatar
    2007-09
    Raleigh NC
    753
    Default system specs
    I'd like to know what other people are using. Here are mine, I cannot run large models very well....
    OS Name Microsoft Windows XP Professional
    Version 5.1.2600 Service Pack 3 Build 2600
    System Manufacturer Dell Inc.
    System Model Precision WorkStation T3400
    System Type X86-based PC
    Processor x86 Family 6 Model 23 Stepping 6 GenuineIntel ~3158 Mhz
    BIOS Version/Date Dell Inc. A08, 8/14/2008
    SMBIOS Version 2.5
    Total Physical Memory 4,096.00 MB
    Available Physical Memory 1.67 GB
    Total Virtual Memory 2.83 GB
    Available Virtual Memory 2.79 GB
    Page File Space 6.36 GB
    Name NVIDIA Quadro FX 570
    Adapter Type Quadro FX 570, NVIDIA compatible
    Adapter Description NVIDIA Quadro FX 570
    Adapter RAM 256.00 MB (268,435,456 bytes)
    ... what would you recommend upgrading. Thanks.
    2007-06
    Melbourne, Australia
    602
    Default Re: system specs
    Hi Bryan,
    Looking at the list above, it would seem that the 3gig switch may not have been set on your machine. That is probably the first thing I would do as it is relatively easy and doesn't cost anything. Have a look through this or the hardware forum (or google) for instructions on setting the switch.
    Otherwise, the big improvement for me was in changing from 32bit xp to 64bit vista.
    64bit vista gets to use all of the ram available.
    One of my machines is a similar spec to yours with 4gb ram and has no problems running 100mb models. As most of my work is smaller scale, 100mb is pretty much the largest file I typically run.
    Ian
    Certifiable AUGI Addict cliff collins's Avatar
    2003-09
    St. Louis, Missouri
    3,071
    Wink Re: system specs
    1. Windows Vista or Windows 7 64 bit
    2. As much RAM as you can fit in the slots--8GB min.
    3. Fast quad-core processor--Xeon or better w/ hyperthreading; good FBS
    ( Multi-core CPUs are more important for photorealistic rendering )
    4. Decent video card w/ min 256MB and Direct 3D capability; nothing too high-end.
    That would be a good start.
    cheers..........
    Cliff B. Collins, Registered Architect / BIM Specialist
    St. Louis, MO
    2005-07
    Somewhere in the BIM world
    3,140
    There's a thread on the ahrdware section with a benchmark regarding that topic.
  1. Optimal system specs
    By comical_wenger in forum 3ds Max - General
    Last Post: 2012-03-11, 10:15 PM
  2. Specs for possible new system
    By nigeld in forum Revit - Hardware & Operating Systems
    Last Post: 2010-01-21, 07:53 PM
  3. Can these Specs be better???
    By Les Therrien in forum Revit - Hardware & Operating Systems
    Last Post: 2006-10-25, 05:52 PM
  4. Specs on a good VIZ system?
    By CADMama in forum VIZ - General
    Last Post: 2006-06-13, 07:33 PM
  5. E-SPECS
    By luigi in forum Revit Architecture - General
    Last Post: 2004-06-18, 04:46 PM
