Thread: Walls intersecting columns?
    2009-09
    2
    Default Walls intersecting columns?
    Hi. I'm fairly new to Revit, actually I'm still in the learning process. For the last month I've been trying to set up a template for the company I'm working for. All went well and the more I understood the program the more I liked it, but I stumbled over a problem which I just could not figure out, so I thought it would not hurt to ask.
    When a masonry wall intersects a concrete column the column is automatically joined with the wall or a warning appears saying that "One element is completely inside another.". My question is: Can I set the elements proprieties so that when the wall "hits" a structural column the wall is cut out where the column is? If yes... can I go further and ask that, when a wall intersects a column can it intersect like in the drawings attached?
    Hoping that my english was not to bad and that my questions were understood I'm waiting for opinions. We would really need this "detail" to work for a clean technical representation and an accurate material takeoff schedule.
    2005-07
    Somewhere in the BIM world
    3,139
    Default Re: Walls intersecting columns?
    Structural Column will cut the wall while Architectural Column will join it. Structural Column shouldn't give you the totally encloed warning.
    2009-09
    2
    10x dhurtubise for the tip . I have noticed that the priority level of structural elements is higher that the priority of non-bearing elements. The problem by me was that some of my walls were set as bearing, having the same priority as the structural column.
    That being settled could anyone help me with my wall detail? Can the wall be set so it intersects with the structural columns like in the illustration I've attached?
    2005-07
    3,139
    I don't think you could get rid of the line between the wall insulation and the column insulation automatically but you sure can create a column with that shape.
  1. Replies: 5
    Last Post: 2012-07-12, 09:25 PM
  2. Intersecting walls
    By h.s.meijering in forum Revit - Student Support
    Last Post: 2010-02-16, 02:46 PM
  3. Split Face & Intersecting walls
    By DaveP in forum Revit Architecture - General
    Last Post: 2008-03-20, 05:45 PM
  4. Endcaps and Intersecting walls
    By dhallett in forum ACA General
    Last Post: 2005-02-22, 10:46 PM
  5. Intersecting Walls not cleaning up?
    By Jason in forum Revit Architecture - General
    Last Post: 2005-01-21, 04:48 PM
