Thread: Plotting Wipeout objects from Paperspace
    2004-06
    18
    Default Plotting Wipeout objects from Paperspace
    When I plot a layout which contains wipeouts, the paper copy shows the wipeouts as transparent even though the plot preview correctly shows these wipeouts. I have made sure that the 'Plot paperspace last' box is not ticked.
    I am using ACAD 2005 at the moment, but this problem has been with me in ACAD 2000 and 2004; in fact I never successfully plotted a wipeout.
    I'm using an EnCAD CadJet2 plotter with a Heidi driver provided by EnCAD specifically for ACAD 2005.
    Even if I plot to DWF6, I still get this problem.
    Any ideas ???
    13,656
    Default Re: Plotting Wipeout objects from Paperspace
    Hi
    Have a browse of the following thread -
    Background Mask and HP plotters
    I've personally found it really shouldn't matter if "Plot Paperspace Last" Check Box is ticked or not; the important thing is correct Draworder BUT as Standard I have "Plot Paperspace Last" ticked "On".
    Here we have no problem with Plotting drawings that contain Wipeout's in Paperspace (Layout), if possible we always set-up our output devices within AutoCAD to use Heidi Drivers.
    Have a good one, Mike
    2004-06
    18
    I'm still having this problem. I have the correct drivers installed, my draworder is correctly set and I've tried adjusting the merge control in the pc3 file. I've viewed the thread, also.
    One thing worth noting: In the same drawing where I have used wipeouts, I have also used 'background mask' within the mtext command. These masked text objects plot perfectly.
    13,656
    Hi
    Could it be just a "bad" drawing file (so to speak) OR does this issue / problem occur in all your drawing files?
  1. Wipeout to Ignore Certain Objects
    Last Post: 2010-03-15, 01:39 PM
  2. WIPEOUT NOT PLOTTING RIGHT ON PDF'S
    By CAD CHICK MTY in forum AutoCAD General
    Last Post: 2007-05-04, 03:19 PM
  3. Civil 3D 2007 - Wipeout does not wipeout Objects in a floating viewport
    By youngrl501483 in forum AutoCAD Civil 3D - General
    Last Post: 2007-03-14, 09:47 PM
  4. Plotting with a wipeout
    By ameetp in forum AutoCAD Plotting
    Last Post: 2006-04-11, 07:02 PM
  5. Not plotting paperspace objects
    By Coolmo in forum AutoCAD General
    Last Post: 2006-01-25, 01:52 PM
