In the Structural Settings > Moment Symbols, there is a pull-down that implies you can change the symbol from non-filled to filled. But non-filled is the only option. How do I change this? Thanks.
You have to create a family for it. There is an annotation family, and under the categories and parameter setting you can set what the symbol will be used for. The easiest is to open the say the solid triangle, change the settings, do a save as, and load into the project.
