All,
There is a new service pack for the 2010 Navisworks product line that fixes a number of bugs including the following:
General Updates
•Clash Detective. Camera now transitions more smoothly between clash results.
•Object Animation. When adding a keyframe to the end of an animation the object movement now remains consistent.
•Comments window. The ID column in the Comments window is now labeled Comment ID.
•Hyperlinks and Smart Tags. Autodesk Navisworks now remembers Hyperlinks and SmartTags visibility settings between sessions. New Show Hyperlinks and Show SmartTags options have been added to the Options Editor (Interface node).
•Sectioning. The section bar slider now maintains correct settings when user switches between viewpoints.
•Collaboration. When using the collaborate function all window states now remain consistent.
•AutoCAD Interoperability.
oAutoCAD elements are now correctly displayed on the Properties tab of the Selection Tree window.
oInstalling Autodesk Navisworks 2010 no longer causes issues with AutoCAD VBA customizations.
•Inventor Interoperability. You can now view Inventor 'surface models' in Autodesk Navisworks.
•IFC Interoperability. Improved support for IFC 2X2 files. Missing components and misplaced Geometry issues are now resolved.
•Revit Interoperability.
oStructural usage text designated in Revit is now displayed in Autodesk Navisworks.
oWindow and door openings are now supported when exporting NWC files from Revit.
oRevit models modeled in mm now appear the correct size in Autodesk Navisworks.
•AutoCAD Visual LISP. Visual LISP feature of AutoCAD 2008 and 2009 now functions correctly after Autodesk Navisworks 2010 is installed.
You can download here.
Cheers
