Everything works great as far as prompting the user and getting the point but how do you get the command line to clear after the user picks a point or does what you're asking them to do? If you run the same command without clearing the command line, the same prompt shows up after the first prompt, and so on, and so on. See below...
Pick point on screen:Pick point on screen:Pick point on screen:
How do Io clear this and go to a fresh command line "Command:"?
