Thread: Sweep Path in Plan and Elevation
    2007-03
    Salt Lake City
    360
    Default Sweep Path in Plan and Elevation
    Is it possible to create a sweep who's path is drawn in plan and elevation. I'm trying to create a frame that goes around a corner. The corners of the frame are mitered, so I need the sweep to be continuous. Is it possible to do this as one sweep? Or do I need to do make it with a combination of 2 sweeps and voids and join the separate geometries together?
    2015-12
    Vancouver, BC Canada
    3,753
    Default Re: Sweep Path in Plan and Elevation
    It will depend on what you are trying to do but often the easiest way is to create a void form that has your desired path as its edges. You can then pick those edges as your path for the sweep.
  1. Sweep - How to set up a path in 3d
    By stephanschneller in forum Revit Architecture - General
    Last Post: 2016-04-14, 04:34 PM
  2. 2013: 3D Sweep Path
    By engamrsalah in forum Revit Architecture - Families
    Last Post: 2013-07-25, 09:11 AM
  3. sweep profile - always vertical to the sweep path
    By d.stairmand in forum Revit Architecture - General
    Last Post: 2006-11-02, 06:14 PM
  4. Edit a Plan-made Sweep in Elevation
    By narlee in forum Revit Architecture - Tips & Tricks
    Last Post: 2006-07-07, 07:43 PM
  5. Can't sweep along an elliptical path
    By Wes Macaulay in forum Revit Architecture - General
    Last Post: 2004-02-07, 08:04 AM
