Thread: Symbolic Lines
    All AUGI, all the time Jrobker's Avatar
    2005-08
    11,000 feet atop a chute
    955
    Default Symbolic Lines
    I am helping someone in the office with a project.
    I noticed that the exhaust air grilles did not have a strong reference for the symbolic lines.
    I want to align to the constant changing RCP.
    I edited the family from not a reference to strong and saved.
    When I load into project I get the error attached.
    It makes absolutely no sense.
    What to do?
    JR
    "Keeping my view range hopeful."
    2009-01
    111
    Default Re: Symbolic Lines
    I have come across this after going back and editing a family to link the connectors. After reloading the family, I see the same error. Hasn't mattered much because this firm, like all the others I have worked at, are just using revit as an expensive cad tool. I just went ahead and said ok. Graphics looked fine afterwards.
    Revit MEP Moderator mjdanowski's Avatar
    2007-03
    889
    Are you resetting to default parameters? You will get that error if you reload a family which has a different value for something linked to a connector.
    You will also get it if Revit is in a bad mood that day though.
    2007-08
    23
    Hi all,
    I agree with MJ. It sounds like a connector problem.
    BTW there are another 24 warnings on that error - maybe one of them has the real answer to your problem.
    Thanks
    Gary
    2005-08
    955
    Quote Originally Posted by gary.ross.145907 View Post
    Hi all,
    Thanks
    Gary
    The warning is a coordination review, the 24 others are disconnect errors. The Symbolic lines are locked to the 3D geometry of the grilles. The Symbolic lines have nothing to do with any connector.
    No, I am not overriding the values of the existing types.
    JR
  1. Convert model lines to symbolic lines?
    By FWSchreck in forum Revit Architecture - Families
    Last Post: 2009-11-30, 11:01 PM
  2. Convert model lines to symbolic lines
    By petervanko in forum Revit Architecture - General
    Last Post: 2006-11-02, 03:29 PM
  3. Symbolic lines sweep along reference lines
    By dduarte in forum Revit Architecture - General
    Last Post: 2006-04-21, 01:44 AM
  4. Changing Symbolic Lines to Model Lines
    By nnguyen in forum Revit Architecture - General
    Last Post: 2006-01-06, 01:07 AM
  5. Changing Model lines to detail or symbolic lines
    By Jason in forum Revit Architecture - General
    Last Post: 2005-05-21, 10:36 PM
