Thread: Can not pick the viewport
    2008-06
    Sunshine State
    43
    Post Can not pick the viewport
    Hello all,
    Please help, I created a couple of viewports without a problem, I was able to go into them, change scale and modify them to fit my sheet. Suddenly, I created another
    VP to find that no matter how I create it I can not pick it to modify the border. I am able to go into it and change the scale, but when I go to MS and attempt to get the grips to stretch it, I can not pick it. Does anyone have a fix for this? I think there is a command somewhere that allows the picking. Oh! I am still able to pick (and get the grips) on the previously created ones, it is the new ones that are not cooperating. Any assistance is greatly appreciated.
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Default Re: Can not pick the viewport
    Quote Originally Posted by gio_2 View Post
    Hello all,
    Are the viewports you are having problems with on the defpoints layer? If so, make sure layer 0 isn't frozen or off.
    Tim Creary
    S&D
    DILLIGAF
    2002-09
    Madison, WI
    4,439
    That's exactly why you shouldn't ever use defpoints for anything but what it was meant for; Dimensions.
    Dave Peterson
    Acad 2012 - Revit Structure 2013 - Z220 - Win 7 64 - i7-3770 3.4GHz 32GB Ram
  1. Replies: 13
    Last Post: 2011-09-10, 11:16 PM
  2. Pick Box in Viewport is missing
    By Dave289 in forum AutoCAD General
    Last Post: 2009-06-24, 06:07 PM
  3. Using VB.NET to Pick the Active Viewport
    By PellaCAD in forum Dot Net API
    Last Post: 2008-05-14, 08:07 PM
  4. Roof - Pick Walls vs Lines with Pick
    By andrewg in forum Revit Architecture - General
    Last Post: 2007-12-28, 03:28 PM
  5. Smaller Viewport to hide / mask part of a larger Viewport
    By thomas.stright in forum AutoCAD General
    Last Post: 2006-04-05, 11:03 PM
