Results 1 to 6 of 6
Thread: Displaying Wire Size
    2009-01
    196
    Default Displaying Wire Size
    How do you have the circuiting show the AWG size for circuits other than #12? I would like to have a #10 show up on the wire for a 30A circuit, can this be done?
    Revit MEP Moderator mjdanowski's Avatar
    2007-03
    890
    Default Re: Displaying Wire Size
    The wire size is based upon a table in "Electrical Settings". I believe it is based upon NEC 310-16. You set the wire size for each over-current protection setting.
    Matthew Danowski, PE, LEED AP BD+C
    Project Electrical Engineer
    Baltimore, MD
    2009-01
    196
    I want the wire shown on the paper to display the size it is. Does Revit display this info. or not? For instance, in CAD a #10 wire will have show a 10 in the wire. I would like to see this in Revit.
    2009-02
    Houston
    686
    Quote Originally Posted by wags5116 View Post
    Short answer: You can create a tag to show this info. There is already a parameter in the wire properties for wire size, but it is going to show more info than you want. You'll probably have to create a project parameter for wire size (call it something else) and apply it to the wires category. Then create a new tag that reads that parameter.
    2009-01
    196
    Thank you. What do you do when you have a #10 homerun but you tag the homerun to show the panel and circuit number? Can you do more than one tag on the wire?
    2009-02
    Houston
    686
    Yes, you can place as many tags as you want. You'll just have to have a separate tag family for different sets of info you want to show.
  1. Volt Drop & Wire Size
    By Admiral McAwesome in forum Revit MEP - General
    Last Post: 2017-06-01, 02:39 PM
  2. 2013: change wire size tag from 1-#12,1-#12,1-#12, to just #12
    By bulletproofx352446 in forum Revit MEP - General
    Last Post: 2014-03-06, 05:08 PM
  3. 2011 Panelboards-Wire Size
    By jarom in forum Revit MEP - General
    Last Post: 2010-08-18, 07:00 PM
  4. 2011 Panelboards-Wire Size
    By jarom in forum Revit Architecture - General
    Last Post: 2010-08-18, 05:51 PM
  5. AutoCAD MEP 2009 Wire size
    By edsamour in forum AMEP General
    Last Post: 2008-07-09, 08:22 PM
