Results 1 to 10 of 13
Thread: Custom Duct Fitting
    Active Member ntopliffe's Avatar
    2008-12
    San Francisco, CA
    65
    Default Custom Duct Fitting
    Anyone have any ideas on how to create the attached custom duct fitting?
    Any help is appreciated.
    Neil
    Mechanical Engineer
    San Francisco, CA
    2008-12
    San Francisco, CA
    65
    Default Re: Custom Duct Fitting
    There is always this idea:
    Hide the duct in red and use detail lines to show the custom duct, probably the easiest...
    Mechanical Engineer
    San Francisco, CA
    I could stop if I wanted to stykface's Avatar
    2007-11
    Dallas, TX - USA
    352
    Quote Originally Posted by ntopliffe View Post
    hmmm, on a cost basis from the duct shop, you'd think that radical of a reducing offset radius 90 such as that would not be cost effective and probably want to be avoided altogether unless you 100% absolutely cannot run the ductwork without using a transition such as that.
    Tannar Frampton | Dallas, TX | Engineering Department
    AutoCAD MEP 2012 / Revit MEP 2012 | CADTutor | The Swamp
    2007-04
    61
    We do the "hide stuff in view" method as well. I know it's not "BIM-ish", but we haven't been contracted to produce a BIM yet, just use Revit.
    2009-02
    Houston
    686
    Quote Originally Posted by rrubert View Post
    Regardless of whether it is BIM, it simply isn't correct. That's like putting all your light fixtures on the floor and saying it's OK, since "we're not contracted to produce BIM." It looks fine on paper... I know that in this case it probably isn't a big deal, but it is a bad habit that you should avoid.
    Try a swept blend to create the fitting.
    2008-12
    San Francisco, CA
    65
    Quote Originally Posted by stykface View Post
    Space is tight, gotta have it.
    Quote Originally Posted by cporter.207875 View Post
    I am still learning the family creation but I have tried the following:
    1. Use a single sweep blend to define the part. Sounds straight forward but I run into problems with a sweep path that is not planer nor a single element. The path must start at one elevation and end at another, and must be a straight segment followed by a spline segment and finally another straight segment.
    2. Use an oversized sweep blend then void the tops and bottoms with void sweep blends to get what I am looking for. This seems possible but highly time consuming and limited to a single element to define the path as defined in 1 above.
    In short, I've done modelling in Pro Engineer and Unigraphics and other part modeling software and the family creation feature of Revit, from my perspective is limited at best.
    Neil
    Mechanical Engineer
    San Francisco, CA
    2008-12
    San Francisco, CA
    65
    after working on it a bit more I have the following.
    I used a single sweep blend, a single path, the second profile is simply elevated above the first.
    worked like a charm.
    Any ideas on making it completely customizable? generic to easily adapt to any geometric configuration??
    It never ends does it?
    Neil
    Mechanical Engineer
    San Francisco, CA
    2009-02
    Houston
    686
    Neil
    You could add a load of instance parameters and manually change each instance in the project, as needed on a case by case basis. This would probably be the easiest, since you would only need to input duct offsets and duct size.
    Trying to get it to adjust itself automatically would be much more difficult.
    I could stop if I wanted to jlondenberg's Avatar
    2007-03
    460
    Lemme know what you think...
    According to your posted drawing - the top surface of the fitting is planer. So the path for the swept blend can go there.
    Joel Londenberg
    BIM Manager ACH Mechanical
    "The best you can hope for in this life is that your delusions are benign and your compulsions have utility." - Dilbert author Scott Adams
    This is the correct date format!
    2009-01
    111
    I believe this is called a "drop cheek" radius elbow. I also believe the correct spelling is "planar", even in America. Language of course is highly fluid, so who knows; like the weather in Denver, if you don't like it, just wait 5 minutes and it'll change.
  1. 2012: Duct Fitting Area
    By william.wydock263820 in forum Revit MEP - Families
    Last Post: 2012-10-16, 09:53 AM
  2. Duct Fitting With Flange
    By longnhietlanh996328 in forum Revit MEP - Families
    Last Post: 2011-04-07, 08:16 AM
  3. Nested Duct Fitting???
    By bmercado in forum Revit MEP - Families
    Last Post: 2010-10-18, 08:10 PM
  4. Duct Fitting Lineweight
    By phil.pleiss in forum Revit MEP - General
    Last Post: 2010-09-13, 08:08 PM
  5. Duct Fillet Tee Fitting does not look right !
    By nbakhoum in forum AMEP General
    Last Post: 2007-04-04, 03:47 PM
