csgohjmj
Hi;
I am having a problem hatching an object with a solid pattern which I really need HELP from you guys out there. The hatch pattern does not appear at all. Attached is the dwg concerned. I have also checked the (getenv "MaxHatch") and the value is 10000 - the default value.
However, the peculiar thing is that when I copy the object ie the rect "a" in my dwg using the copy with base point function, into another new dwg, it can be hatched. So what is wrong with my original dwg? Is there any system variable which have been changed accidentally whcih I am not aware of ?
