Thread: HVAC Zone Trouble
    2009-02
    26
    Default HVAC Zone Trouble
    I've been trying to set up HVAC zones in Revit MEP2010 for our 100%SD submission.
    I Set up the majority of the zones except i have run into a few problems. I've noticed that a few rooms cause issues when i add them to the zone. What basically happens is the Zone color no longer shows up after these spaces are added. Instead i get a small square in another area with the zone color.
    I attached a specific example. Basically before adding the zone & then after
    Also in another area i am having the same issue. the only difference is that the zone colors don't show at all. These rooms are odd in shape and extend several floors.
    does anyone have ideas as the the cause of this problem?
    2007-04
    61
    Default Re: HVAC Zone Trouble
    My coworker and I had a similar problem on two separate jobs. I believe it is a graphical error. It will fix itself on its own, hopefully before you have to print.
    Also, make sure the spaces are on the correct zone, regardless of what the color fill tells you. If they are on the correct zone, eventually, the color fill will work itself out.
    2009-02
    26
    Quote Originally Posted by rrubert View Post
    Really? Not exactly the reason i was expecting but hopefully it will fix itself sooner than later then.
  1. HVAC Zone Color Fill Problem
    By tlester276119 in forum Revit MEP - General
    Last Post: 2012-06-13, 04:42 PM
  2. HVAC Zone Legend for multiple views
    By adonkle in forum Revit MEP - General
    Last Post: 2011-10-18, 09:52 PM
  3. [2009] Space information in the HVAC Zone Schedule (OPEN)
    By JoelLondenberg in forum Revit MEP - Wish List
    Last Post: 2010-03-04, 03:13 PM
  4. HVAC Zone Color Legend
    By rrubert in forum Revit MEP - General
    Last Post: 2009-09-24, 12:34 PM
  5. Mechanical(HVAC) Zone is not exported to IFC 2X3
    By bingcat2007 in forum Revit MEP - General
    Last Post: 2008-10-25, 01:25 PM
