Thread: TFRAMES
    2005-04
    77
    Default TFRAMES
    What command do I use to turn on and off wipeouts and image borders. When I type TFRAMES it says: Cannot set IMAGEFRAME to that value *Invalid*
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Default Re: TFRAMES
    Well, TFRAMES is an Express Tools command, and generally you don't set it to a value. You just type TFRAMES, and it should toggle both values. If that's not working, I don't know why.
    You can always set them directly. For images, type IMAGEFRAME, and set it to 0 (off), 1 (on, plots on paper), or 2 (on, does not plot on paper). For wipeouts, type WIPEOUT, then type F (for FRAMES), then type ON or OFF.
    2007-10
    41
    Default Re: TFRAMES
    In 2010 there is a variable called FRAME, which controls reference frames:
    0 = Off
    1 = On and Plotted
    2 = On and not plotted
    3 = Individually set by IMAGEFRAME, PDFFRAME, XCLIPFRAME, DGNFRAME
    It does not set wipeout frames, but you could very easily create a command that sets all of these for you.
  1. Frames and Tframes
    Last Post: 2016-07-22, 10:25 PM
  2. TFRAMES
    By mermercad in forum AutoCAD General
    Last Post: 2012-04-25, 12:47 PM
  3. Image frame displays partially when tframes set to off
    By bcowper in forum AutoCAD Plotting
    Last Post: 2005-12-23, 10:15 PM
  4. Tframes not working as per normal...
    By lem_102074329 in forum AutoCAD General
    Last Post: 2005-12-08, 04:39 PM
  5. TFrames command produces Error
    By neilcheshire in forum AutoCAD General
    Last Post: 2005-10-31, 02:10 PM
