Thread: edges in massing 2010
    2009-03
    105
    Default edges in massing 2010
    ok, so i draw a square on level one and click 'create form'. i now have a 6 sided box. if i want to add an edge i click 'add edge', same with 'add profile'... but my problem is i can only add edges and profiles to vertical faces, no watter what i try i can't get seem to add an edge to a horizontal face (even after setting the horizontal face as the working plane). am i missing something or is it not possible to add an edge to a horizontal face?
    2009-03
    105
    Default Re: edges in massing 2010
    (bump)
    anyone?
    AUGI Addict jeffh's Avatar
    2002-09
    Manchester, NH
    1,081
    It is not possible to add an edge to a horizontal face.
    ______________________________________________
    Jeff Hanson
    Sr. Subject Matter Expert
    Autodesk, Revit User Experience
    Revit Technical Specialist - Autodesk Scott Davis's Avatar
    2003-04
    Chino, CA
    4,743
    when drawing the shape before the "Create form" button, use multiple segments that connect at endpoints. The points will create a "seam" that can then be edited, much like adding an edge to a horizontal face.
    Scott D Davis
    AEC Technical Specialist
    Autodesk, Inc.
    http://about.me/scottddavis
    2009-03
    105
    Thanks guys!
    At least i know now...seems these Revit modelling tools still need a lot of development.
    i think i'll go and make a comment on the wishlist!
  1. Massing - Unwanted Edges
    By barrie.sharp in forum Revit Architecture - General
    Last Post: 2011-11-25, 07:36 AM
  2. New Massing Tool 2010
    By kidess.68812 in forum Revit Architecture - General
    Last Post: 2010-08-01, 10:34 PM
  3. 2010 Massing Tool
    By sjsl in forum Revit Architecture - General
    Last Post: 2009-07-29, 09:21 PM
  4. Revit 2010 Massing
    By cadman6735 in forum Revit Architecture - General
    Last Post: 2009-05-07, 05:02 PM
