Please find attached a zip of cable ladder families I have created in revitMEP 2010. All based on unistrut metric dimensions (Nema12 through to Nema20C). Project file "Ladder.rvt" has families for individual sizes, "cableLadder-all.rfa" was the original file with family types for sizes (see my parametric modeling questions).
As a complete newcomer to Revit I have several questions, some very basic, as to their use / suitability for use in a project that the forum may be able to help me with. My questions being:
Basic 2D representation
-When used in a plan I only need to see parrallel lines and perhaps a centreline. I've tried drawing in model lines but the message comes up saying the created lines aren't viewable on the reference level. Is this a setting I can control in the family? or only in the project?
-In an elevation, a similar situation after I added a rectangle to show only the rail depth.
-As detail level goes up in the view can I add fine lines to represent the outer edge of the rail? (say at greater than 1:50)
-Do model lines have to be aligned with the controlling reference plane to be stretchable? I can't seem to select them in the align command in the family editor.
-How to hide the models rungs (a variable array) in plan and elevation views using visibilty settings?
My main interest here being to cut down on regeneration (yes! my autocad background)
Parametric Modeling (see the cableLadder-all.rfa file)
-I thought I would be able to change the rail profile in one common family by adding a family type with a parameter <family type>-profile for the profile used to create the sweep ie nema12 rail profile. I can get the dimensioned planes to move to suit the selected family but can't get the instance of the rail profile to change by setting the <family type>-profile parameter. I can manually change the rail profile in the instance within the family. I think my problem here is how to label the sweep so as it is available as a parameter.
-As above I thought I would be able to mirror the profile (or control the flip) or use a sub-family profile to display inward facing rails (ie nema 16a-ir).
My main interest in using parameters is to minimise the family file size. (yes! my autocad background)
Connectors
-I have tried different family catergories, Electrical fixture, Electrical equipment, Generic model etc but can't seem to get a connector type that that at least namewise appears suitable. The families are all saved with generic model family catergory even though cabletray is an option as an "omniclassTitle".
Here I am assuming I will need connectors when I create fittings (tees/cross tees/reducers/bends etc).
-Can connectors be inserted at reference plane intersections?
- Can I have "strong and weak connectors" so I can locate the ladder at a suitable offset from a slab soffit? Ideally to automatically set the ladder at beams, level changes etc.
This is my first attempt at revit modelling so all the files are based on the help file tutorials. If a forum member has the time to check the constraints, dimension locks etc and give some real world insight as to my family construction it would be greatly appreciated. Any comments the forum might have on the families, any answers to my questions, or any tips or forum links would be also be greatly appreciated.
With thanks pth
