Ok- so i wrote a lisp routine a long time back to be able to set all the variables to plot so that i don't have to go through the mind numbing task of making sure the print variables are all set the way i need them to be every time i print. Basically i made the lisp and then run it through a macro button so it's quick and easy. Until now...
My company just installed new printers and here's the issue i'm having. The new printer calls what used to be ledger now 11" x 17" - and when i try and enter that 11"x 17" because of the quotes- it kicks my lisp out the door.
Can you think of a way to work around this? Is there a way to put the 11" x 17" into a lisp routine so it doesn't force it to think it's part of the routine?
Here is the full lisp routine.
(DEFUN C:PLOT4000()(COMMAND "-plot" "y" "" "Ricoh 4000.pc3" "11"x17"" "i" "L" "N" "W" "0.000000,0.000000" "36.000000,24.000000" "Fit" "C" "Y" "$VI_HALF.ctb" "Y" "Y" "N" "N" "N" "N" "Y"))
Thank you in advance.
