Thread: cant check in features - features remain in edit set
    2008-08
    7
    Default cant check in features - features remain in edit set
    I am trying to create a join, but when I do so I get the following message:
    Feature was not saved in the target feature source
    Message details:
    Features remain in the Edit Set.
    So I highlight my data and click "check-in features" or I click "select checked out features" and then "check-in features" and I get the message:
    Message details:
    -Failed to update feature
    -1=Failed to execute Fdo command
    -2=Int32Value is null
    I think this might be because my "FeatId" property has many "null" values and is data type Int32 or because my "export_sdf_id" property which is also data type Int32 is grayed out. My schema editor will not let me edit anything either.
    What should I do?
    Thanks
    2008-08
    7
    Default Re: cant check in features - features remain in edit set
    I am using Map3d 2008
    South Eastern US, exact location unknown
    1,369
    What data type are you making the join with SDF, shp, ODBC ?
    J. Murphy
    AKA
    Murph
    The former AutoCAD MAP3D Power User
    2008-08
    7
    Im trying to join an ODCB to an SDF. The SDF has geometry points and some of the data I need, the ODCB which comes from an excel file has all the data I need.
  1. Check in features
    By dawn.pedersen309807 in forum AutoCAD Civil 3D - General
    Last Post: 2012-03-20, 10:51 PM
  2. RST vs RAC features
    By UpNorth in forum Revit Structure - General
    Last Post: 2009-12-01, 11:28 PM
